Thought it may interest you if you haven't started the rebuild on your current engine. The engine you were talking about earlier in the post (VK56DE) has been listed on EBay with a Buy it now of US$2500, 2006 build and only 5000 miles on it.
Look up EBay item no- 130092922424, not sure on cost of shipping it to Oz but worth asking about anyway.
  • 4 weeks later...
  • Replies 390
Posted Images
Cheers mate, had a look at that but im back at uni now so funds are limited.
Ran a 10.17 @ 131mph on weekend blew the head gasket... it seems we've reached the limits of the stock head gaskets.. i have some coppers sitting on my desk.. the block is off to be oringed all the good stuff from the old heads will be changed over to the new heads.. just trying to track down a set of rings and bearings and it will be back to the track.
Also the new torque convertor is flaring to something like 6000 rpm and therefore running very inefficiently once this is sorted i can forsee easy 9's, bring on the winternats.
Edited by NA_R33
  • 2 months later...
Quick update on the shitter.. block is back from Mendhams, rings and ring grooves in place, heads should be ready next week, there also getting a tickle up while at the machinest, just about to order rings and bearings and should have the stally back next week, so within a month she should be up and running again, bring on the 9's
Just finished reading this whole thread.
That is one awesome machine. U have done what most of wish we could do (extreme power and times with different engine swap).
Well done mate. Really looking forward to seeing what this thing has in store for us into the future.
Chris
he makes it all sound so easy doesn't he?
i've grown up with this car and seen everything john has done to it, there's been a lot of R&D, money, time and effort put into it.
easily competing with the top dollar dragsters in australia with a two man team (john & mechanic) and with a realistic budget!
good luck with 9s dude, will be there when you do!
No no that was quite correct, that was with a full exhaust, running ~5-6psi on 50/50 Pulp/Toluene, shes had a few changes since then :(
Cheers for the comments guys, Much appreciated :(
Rings and bearings should hopefully be here this week, so it looks like we may get a run at Jambo after all, should be interesting.
Im hoping to mate, i wanna come up for it, see u dip into the 9s been a long road since that week in ur pop's shed when we put that motor lol. its an animal now, remember u coming to grips with it being an auto to lol
Yeah for sure dude, i think were gonna be camping out there and when were not ur welcome to stay at mine and the trailer is plenty big while were out there.
Well i got ahold of some hard blok, so the block will be grout filled.. should hopefully have it running sunday, have been some delays with getting the crank ground... the workshop doing it couldnt find any specs on it, but thats all sorted now..
ooooo now were talking full race spec build
half filled or fully filled?
thats gonna need some massive water pump and hi flowing head
you ceramic coating the water galleries for better flow and less cavitation?
Hahaha, its coming its coming, the machinests have beens stuffing around with the crank and block its... still not done, should pick it up tomorrow, wish we had the machines to do it ourselves at our workshop, one day....
Its going to be a full fill and the water will just sit in the heads, it hasnt run a water pump for a while. It runs for less than a minute each pass... its fire it up, burn out, run and shutdown.
With no water pump the temps are no higher than 92 degreese (celcius) shut down at the line and creaps too 110 after heatsoak... Running methanol which cools intake charge temps and a colder combustion (to my understanding?).
for the others,
methanol (100%) is often used in anti-freeze due to its cooling nature, (low freezing point at -80ºC ish)
like you said it is more flammable with a lower flash point:
methanol flash point is around 10-11ºC
and petrol, depending on its mixture would be around the 40-50ºC mark i would guess?
just a bit of background in case anyone was wondering why he's doing what he's doing.
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
