  • Replies 390
Posted Images
yep makes sense
the guy i work for during uni holidays runs 3 cars in teh AMCA series (like super sedans - Holden 253 v8's on HZ front ends with custum body's)
1 is running methanol and he was saying that it runs a 14:1 comp ratio, whereas the other two are running PULP and are only at 11:1
methanol is a cooler burn allowing a higher comp ratio to make more power (but requiring 3 times the amount of fuel, and massive big fuel lines - try thicker than your thumb, internal diameter about the thickness of your pinky finger!!!)
thats interesting that in that short amount of time it gets to 92 deg
im trying to understand how you run it - is there a radiator at all? or an overflow type bottle with a high pressure radiator cap to increase the boiling point of the water?
Thanks for the replys.
No radiator, the copper head gaskets do not have water jackets. So the heads are just filled with water and connected to a overflow tank to allow for expansion.
Well after alot of work over the last few weeks today it all came together, but unfortunately we will not be racing at jamboree. The block we prepped and filled actually has a massive crack between cylinders 4 and 6 where the drivers side bank meets the valley. This is were the problem originated, unfortunately it was not picked up in testing, it appears that the head stud has tried to pull that section of the block away from the rest of it. Grout filling will hopefully stop this on the next engine. Fortunately i have another block, so it will be prepped and o'ringed and we'll begin changing everything over. Were also going to redesign the supercharger drive system to put less stress on the front of the crank. So we will now be aiming to race at street car shootout in about a months time i think... not sure on exact dates.
ROFL!! haha cheers mate.
Well we tryed fevourishly to weld and devcon the block up just so i could get a run at jambo, but it was cracked in a few more places then we would see without pulling it out of the car and stripping it, luckily due to rain we wouldnt have been able to get a run anyway. the spare block is being cleaned and crack tested this week, then will be sent to have the deck surfaced and o'ring grooves machined. Then it will be simply a case of changing everything over...
  • 2 months later...
Well its been a while, but the car is back together and seems to be running well.. we will be heading out to willowbank tonight for some testing before jamboree this weekend. Ill keep you all posted..
well unfortunately willowbank couldnt get an ambulance on standby so the test n tune was cancelled, so its out to jamboree tomorrow to see what she'll do.... should be interesting
i want a text tomorrow saying "f**ken aye giggidy 9 second pass"
Well MISH!!! convertor came back wrong... its only flaring to 3000 so it bogged terribly off the line managed an 11.6 before giving up... then when putting it back in the trailer we noticed some sort of death rattle comin from somewhere... havent had time to look at it yet....
Somebody say big block chev??
Well still havent looked at it yet, but if it is the engine we will be going with a NA injected 454 simply for simplicity and reliabilty.
Its sad it cant stay nissan but its simply not viable to continue the nissan route on my budget, i think what i have acheived on a virtually standard internals engine is only testiment to how good these engines are, perhaps in the future when money is less of a problem i will continue the R n D with the VH.
Thats a very interesting suggestion u have there....
full of bright ideas dude! put the biggest farken nozzle you got.
shame that it's being such a mish... was so promising!!! any idea what the death rattle is? something loose in the cylinder? :)
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
