Hey guys i have a skyline which i owned for 4 years but i am parting all the parts. i have moved on and dont wish to continue finishing the car off. Getting old so need this car gone.
List of parts on for sale as is.. ALL BRAND NEW PARTS. NEVER DRIVEN. 0KS ON MOTOR..
R33 GTR ENGINE WITH 2.8 TOMEI STROKER KIT
HEAD HAS BEEN PORTED AND BLUEPRINTED. BLOCKS BEEN MACHINE AS
BUCKETS AND SHIMS AND VALVES ALL 1MM OVERSIZED
WELL. BY JHH IN BRISBANE QLD
HKS STAGE 3 CAMS
TOMEI CAM GEARS
TOMEI OIL PUMP
ATI HARMONIC BALANCER
HYPERTUNE PLENIUM AND FUEL RAIL AND HYPERTUNE THROTTLE BODY
SARD 1000CC INJECTORS
T88 38GK 1200HP TURBO KIT (AIR FILTER, BLOW OFF VALVE AND HOSING AND CLAMPS
MOTEC M800 ECU WITH 9 BOOST SWITCH SETTING AND 3 BAR MAP SENSOR
FULL WIRING LOOM FOR RB26DETT ON R33GTST
GREDDY MANIFOLD AND DUMP PIPES
TOMEI HEADGASKET KIT
BUDDYCLUB COILOVERS ALL ROUND
VOLK GTC FACE 2 WHEELS 18 by 8.5 front and 18 by 9.5 rear
FULL CUSTOM KIT
3 INCH HOOKER EXHAUST SYSTEM
PWR 3INCH INTERCOOLER KIT
PWR OIL COOLER KIT
PWR RADIATOR
SPITFIRE COIL PACKS
3 DEFI GAUGES MOUNTED ON PASSENGER SIDE DASH WITH UNIT
APEXI TURBO TIMER
GREDDY PROFEC B BOOST CONTROLLER
2 WALBRO EXTERNAL FUEL PUMPS
BRAIDED LINES THROUGHOUT THE CAR AND UNDERNEATH THE CAR
ROLL CAGE PADDED
RECARO SEATS WITH RAILS
ROCKFORD FOSGATE COMPLETE SOUND SYSTEM
CUSTOM SURGE TANK MOUNTED UNDERNEATH REAR BAR WITH ALL BRAIDED LINES
FROM WHAT I HAVE TOLD. SPEND ANOTHER 10K ON THIS CAR AND U WILL HAVE 1000HP REAR WHEEL DRIVE R33 SKYLINE
THE LIST GOES ON AND ON. THE WORKSHOP HAS RECIEPTS FOR ALL THE WORK DONE TO THIS CAR.
CAR IS LOCATED IN BRISBANE QLD.
MOTOR ALONE WAS 30K TO BUILD. STROKED MACHINE AND PORTED
ONLY SERIOUS BUYERS ONLY
OFFERS
RING ME ON 0423451393 FOR MORE DETAILS
ALL PARTS LOCATED IN BRISBANE
Edited by hungy81
https://www.sau.com.au/forums/topic/357651-r33-setup-for-sale-brand-new/
ENGINE WORK DONE BY JHH IN BRISBANE SLACKS CREEK, QLD
HKS STAGE 3 CAMS SHAFTS
TOMEI CAM GEARS
TOMEI OIL PUMP
TOMEI BAFFLE PLATE IN SUMP
CUSTOM SUMP TO RUN ONLY REAR WHEEL DRIVE
HYPERTUNE PLENIUM AND HYPERTUNE FUEL RAIL AND HYPERTUNE THROTTLE BODY
FULL CUSTOM BODYKIT
3 INCH HOOKER EXHAUST SYSTEM WITH HKS DRAGGER TIP
PWR OIL COOLER KIT
PWR RADIATOR
SPITFIRE COIL PACKS
APEXI TURBO TIMER
2 WALBRO 044'S EXTERNAL FUEL PUMPS ON SURGETANK
ROLL CAGE PADDED
JVC DOUBLE DIN HEADUNIT
TINTED WINDOWS
DOLUCK SIDE SKIRTS
ADR APPROVED FIBREGLASS VENTED BONNET
DOLUCK REAR BAR WITH DIFFUSER
MSPORT FRONT BAR
DBA FRONT AND REAR SLOTTED ROTORS WITH FRONT EBC GREEN PADS
PAINT JOB DONE BY DMD THE IMAGE CHERRY BLACK
CAR ISNT FINISHED YET. SPEND ANOTHER 10K ON THIS CAR AND U WILL HAVE 1000HP REAR WHEEL DRIVE R33 SKYLINE
NEED GEARBOX OFF UR CHOICE AND CUSTOM TAILSHAFT TO HANDLE THAT POWER AND FEW BITS AND PIECES. ALL ADDS UP
OFFERS
CAR CAN BE VIEWED IN PERSON AT 101 MOTORSPORT SLACKS CREEK
Edited by hungy81
Thread closed.
This is the parts and accessories FS area.
If you are selling the car as a whole, please open a new thread in the Whole Cars for sale section, and include an asking price and more information about the car itself.
Asking for offers without stating a price is not permitted.
Thanks.
Admin
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
