Hey guys I need some help please. I have a r34 GTT recently I did a few mods to my car and one of those mods were injectors.
I chose to use the NISMO s15 480cc injectors. as you all know these are side feed, so i had to chnage my fuel rails to r33 side feed rails.
Becase i changed that I alo had to chnage my stock plenum to r33.
What i didnt know unitll i had chnaged the plenum over was the IAC vave on the r34 plenum was at the back
The IAC valve for the r33 pleum is at the front the bolting holes are also different.
Also he r34 is a AAC/IAC built in one.
Where as if i just go any purchase a r33 IAC valve and straight bolton i wont have my AAC.
My question is there anyway to fit my stock r34 IAC valve on to the r33 plenum?
Has anyone ever done any custom work to make this work or know of anyone or anyplace that can help me.
i would really appreciat it.
actually it wouldnt be that hard to convert the IAC, just drill and tap new holes to mount it and make a hole for airflow. might find you can reuse at least one of the original boltholes and the main airway too.
I made a blanking plate for mine in the old r33, and with a rips plenum i had to start from scratch just as above.
Obviously taking the top half of the plenum off would make it easier.
What do you mean? A R33 is a Idle Air Control and Auxilary Air Control valve in one just as the R34 one is.
But yeah definetely should have just bought Neo injectors.
Guys i know if i just got top feed injectors may have been easier ok but more expensive. I Got the rails 6 injectors and side fuel rails all pretty cheap.
ANyway PM-R33 are you sure A R33 is a Idle Air Control and Auxilary Air Control valve in one just as the R34 cause then i'll just go pick one one and straight bolt on right?
Bro seriously, you can still sell all that gear and buy some top feed injectors!
It'll only cost ya a few more hundred dollars, instead of weeks of headf**k. I dunno why you've gone to all this hassle when you could've bought the right injectors in the first place?
There's no guarentee that the R33 idle valve will be controlled exactly the same as the R34 one. It might have a different plug and different ECU signal.
I can foresee soo much fail in this set-up!
I agree. just sell the gear you've bought and buy the right injectors for your original set-up. what an effort changing all that gear just to have 480cc injectors. it's nuts.
Yeh I would swap back if I were you mate. I bought my 650cc PWR injectors second hand for $500, they plugged straight in no messing around. I do understand why you were tempted to go to side feed injectors though, plug and play injectors for R34's are either ludicrously expensive or ridiculously hard to find! I found some in the end though, I think it would be the better option... If you are comfortable using Siemens injectors then they are an easy/cheap option, my tuner just told me to stay away from them.
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
