Hey,
I am now looking for a new ECU for my 1999 Nissan Silvia S15. Over time I have been told how good the Apexi power FC's are for my car and have read a lot of import mags that show a lot of people using them. When I brought this up with a couple of mechanics they rekoned that the power FC is old tech/a biatch to tune and to go with something newer like the Vi-PEC V88. Does anyone have any experience with either of these ECU's or have any recomendations which they have used in thier own car. Would love to get a better insight into this issue before I go and blow a lot of money on the wrong thing.
Cheers
https://www.sau.com.au/forums/topic/357731-vi-pec-or-d-jetro/
Depends where you're gonna get it tuned man.
ESP = ViPEC
Autotech = PFC/Autronic
Personally I went ViPEC coz PFC for R33 GTS-T is old as all hell and hard to find a good condition 2nd hand one, plus the support from ViPEC is amazing. Call them with a question or query and 99% of the time they'll put you straight onto Ray Hall himself. Good bloke too.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
