Hey guys would just like someone to confirm for me, I have a atmosphere venting bov, from what I've read up on it the screw on top of the bov adjusts how firm the valve spring is, the tighter it is the harder for air to vent, when boost isn't high enough air vents through the turbo which creates the fluttering sound which isn't good for your turbos life, when boost is higher it vents from bov and u get normal ppsshh sound, so looser screw equals less flutter and better for turbo, tighter equals more flutter, also I seem to get boost restricted with screw done tighter? Does this mean it is over tightened? Thanks for any help, I realise there are threads on similiar topics but everyone always talks about these things as if u already know what they are talking about so for a noob it's hard to follow....
https://www.sau.com.au/forums/topic/357748-atmo-bov/
i had my blitz one on for a while till it just annoyed the living crap out of me. but besides that, take off your air filter top and the air filter, bolt on your BOV etc, then turn your car on, rev your med-high, then just let go, if you hear a psssshhhh, then your BOV is working, if you hear a flutter your screw is too tight, loosen your screw.
if it is still psssshing, tighten your screw just before you hear a flutter. then you have max boost your turbo is set to (factory 7 or 8psi). if you loosen your screw too loose, then you will loose boost, the lower your screw the easier it looses psi, it will let off at 4psi instead of 7psi, so kind of a giant power loss
https://www.sau.com.au/forums/topic/357748-atmo-bov/#findComment-5717923
tighten the screw = more flutter
loosen = more psssh
think of it like a water tap - tighten it and it lets less water out, tighten it all the way it lets no water out. think of water as the air inside your intake, and you're on the right track.
having it tightened all the way up won't restrict your max boost - only your spool time between gear changes. the only risk to boost with a BOV is having it too loose, which can result in boost leaking past the valve.
is it truly a vent to atmoshpere BOV? or is it plumbed back into the air intake? if it really is a true atmo BOV then my advice would be to run it pretty tight - having it open up all the time will result in getting bad air/fuel mixtures as it dumps metered air out and causes overfuelling - which will just hurt your hip pocoket. it will make it flutter a bit more, yes, but don't buy into what everyone tells you about it hurting the compressor - VL turbo's dose all day long on 20+yr old bush bearing turbos and have no issues.
if you want to increase your performance, and your engine's efficiency - get that baby plumbed back or put the stock unit back on. it will be quieter, legal by the EPA, and your car will go harder.
https://www.sau.com.au/forums/topic/357748-atmo-bov/#findComment-5717934
Thanks guys, it's definitely atmo, stock one is still
on the car just blocked off so if I have a run in with the boys in blue it's easy to reverse to clear a defect, so far since it went in I haven't noticed any loss in economy but I guess my car has been overfueling since I got it anyway, and I should have mentioned it's not running stock boost, it normally runs around 11psi but I swear when the screw was really tight it was maxing out at 9-10 psi, maybe I was imagining it, as it is ATM I get flutter up to about 7 psi then ppsshh above that
https://www.sau.com.au/forums/topic/357748-atmo-bov/#findComment-5718090
How does the boost leak past the valve when there is an equalising pressure from the plenum acting on the top of the valve? As long as the spring is physically holding the valve shut when the engine is off then it will only crack when the pressure in the intake is greater than the tension on the spring.
I couldn't agree more. Get rid of the aftermarket BOV. There is nothing to be gained by using it.
https://www.sau.com.au/forums/topic/357748-atmo-bov/#findComment-5718370
only replace your old one when you want more boost, your old one is set to dump at 7psi i guess, so even if your turbo is set to 11psi at the wastegate, those 11psi wont even get to your engieon cause your BOV wont let it go beyond 7psi.
get a nice adjustable plumb back one
i do still think that surging is bad on the turbo though, spinning freely at a couple thousand rpm to the right and then all of a sudden a stop and turn other direction will put strain on your ball bearing/journal bearings
besides your atmo giving you shit fuel economy and missfiring, your car will hit boost slower between shifts since its wasting that extra amount of air your ecu already accounted putting petrol in for.
https://www.sau.com.au/forums/topic/357748-atmo-bov/#findComment-5718714
Ignore this, the stock bov does not release air pressure above 7psi, if you run 11psi the engine see's 11psi.
The only issue with the stock bov is that it's getting old, I had mine let go at 14-15psi where as others have no problems holding 18psi. What Wolverine said is correct, on a bov in perfect working order the equal pressure will hold it shut. The stock bov is old, the seals are worn/shrunken/deteriorating and may pass air causing the bov to release under load.
In the end run whatever setup you want, atmo bov isn't that big of a deal if you can put up with occasional stalling, and pops and black smoke out the exhaust when backing off. IMO fuel economy is hardly effected dispite what some people will try and argue.
And again IMO a little reversion (flutter) isn't a big deal either, It won't effecting the stock turbo's response to a point where it's noticeable. And to anyone who says it will damage to turbo and Nissan put a bov there for a reason, the RB20 out of the cefiro does not run a bov at all.
Edited by QWK32
https://www.sau.com.au/forums/topic/357748-atmo-bov/#findComment-5718859
Thanks for all the opinions fellas, loss of economy does not concern me as like I said my car has run rich from day one, I get back fires when backing off full acceleration before the atmo bov went in, currently saving for a nistune and turbo rebuild to sort it all out, oh and the new bov does hold boost better then my stock one did
https://www.sau.com.au/forums/topic/357748-atmo-bov/#findComment-5719083
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
