I've started looking into graphics cards and have been wondering whether to go a high end older card or a mid-range newer card.
One factor is the directx support. I had no idea what the difference was until I stumbled across this thread (yes, it's from 2009) that explains and shows the differences very well.
http://www.overclock...-vs-dx-9-a.html
I tried using the ol' search button but didn't find anything explaining the differences.
Here are some pics of the same scene, but under the different versions.
post-51176-0-50216500-1300341329_thumb.jpg You'll notice that the differences between DX9 and 10 are minimal with only better shading and light
post-51176-0-42146100-1300341362_thumb.jpg DX11 is like a whole different league; more 3Dness so to speak - the biggest change is the detail in the road.
I know it's an old subject and I'm a couple of years behind but I figured it's good to know the differences. DX11 is definitely the way to go.
Windows XP - DX9 ONLY
Windows Vista - DX10 (can be updated to DX11)
Windows 7 - DX11
https://www.sau.com.au/forums/topic/357762-directx-11-vs-dx10-vs-dx9/
i would go Dx11 no point going backwards
and something like ati 6870 1gb is pretty cheap nowadays
http://msy.com.au/product.jsp?productId=6837 $229
i can only find 1 Nvidia in a similar price range
http://msy.com.au/product.jsp?productId=7305 $277 GTX560
the 6870 is probably a higher binned 6850. So whilst it may work on most cards, there is potentially a portion that won't work after flashing it. I could be wrong though, cbf researching.
BTW that directx 11 shot seems to be showing off tesselation more than anything ;)
Well apparently that's what dx11 is all about. It's basically dx10 but with completely revamped tesselation properties.
I think instead of having multiple levels/layers of models, they have only two. Dx10 and earlier would have the lowest detailed model up close covered by the next level, covered again by another level and so on; therefore all levels are loaded for up close models even though we only see the last level/layer. Dx11 on the other hand will only load the highest detailed model close up until a certain distance and then change to the low detailed model.
6850 is same as a 6870, with minor diffs, but you reflash bios and it works 100%, out of the 30-40ish ppl i know on the overclocking forums, all their cards work fine :)
DO IT!!!
i for one, just bought the gtx570 which just kicks pure assssss!!!
Windows 7 - DX11
in dx11 that road is retarded, theres no way anyone could walk on that without twisting an ankle
[quote name=ClutchBurndout-:(' timestamp='1300745012' post='5724470]
Haha. Fk driving on it too. Stiff suspension + road like that = fkd spine; and forget it if your busting for a piss.
Hey guys,
I just installed a genuine copy of Windows 7 64-bit Home Premium.
I am not sure if my operating system is now running Direct X 11. How can I tell or where do I search in Windows 7 to find if it is?
My PC specs are as follows (if its of any importance) -
  • Intel Quad Core 3.2ghz
  • 4.0gb 1333mhz ram (yes I know that's sh!t, i'm upgrading to 12gb 2000mhz soon!)
  • Gigabyte 1gb graphics card (can't remember the exact model name, paid about $300 for it just over 12months ago)
  • Asus mother-board (once again can't remember specs etc)
My PC runs games such a COD: Black Cocks & Battlefield: Bad Company 2 one maximum graphics and runs both of them smooooooooth as silk, both in singleplayer & multiplayer. WoW runs perfectly smooth, you get the idea.
I'm pretty sure my graphics card is an ATI Radeon HD 4850.
It seems to perform very well, and when i had XP and the Catalyst Control Centre installed, i overclocked it and it still ran fine and didnt overheat etc
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
