Hey guys and gals,
We are an automotive retailer mainly dealing with performance products.
Right now we have been in contact with a manufacturer of top quality (non Chinese) turbochargers that are priced very competitively and still utilise parts from Garrett.
As we are aware of the dangers in selling sub-standard turbochargers we have taken our time in choosing a good manufacturer.
We have never sold turbochargers so we are looking for you guys to help us out and tell us what you think would be popular and in demand.
Sizes, HP ratings ect. anything really that would help us in deciding what to start off with importing.
Your input would be greatly appreciated!
Thanks in advance,
Brendan
A bolt on RB25 turbo that makes around 260-270rwkw.
It must be responsive, ball bearing and around the 1500-1700 price mark to better Garrett who are making a killing in that area.
Using as near to factory size/looking housings as possible.
That is the market seller IMO and most common choice
this!
That to but best to bring a few in and try them with different applications as a Trial and see the overall response the only way to sell is with proven performance as we all no it may look good on paper but in the flesh or steel it can be bad just my opinion
Edited by base308
22-24psi and a aggressive tune on -5s will do that.
ya dont need need -10s, they are 450 region.
I think the GTR bolt on market is quite well filled with garrett, and the turbo prices are quite reasonable.
add to the fact its hard to test/swap turbos, and GTR owners mostly choose what works for that reason.
its RB20/RB25 even 25/30 where the most sales and gain is from a business perspective.
how about a bolt on kit for the holset turbo range? re-sell the internal wastegate type, get someone to make up dump pipes, oil lines made up and a recirculating water pipe made up and a 15-20mm spacer.
these turbos sound great, cheap to run, proven results, and are cheap to rebuild and push upwards of 300kw. the only down side is they are bush bearing (which hasnt caused any dramas) and there are no bolt on options for the rb's.
Yep, stock looking turbos for RB25 producing about that much power and work with existing manifold, dump, intake piping and possibly lines.
The stock intake pipe wont work in my experience over 250rwkw. A replacement intake pipe that looks factory would be great, I had to make mine up.
Is that because of size or because factory one collapses under pressure?
I sort of meant factory in terms of size, but yeah, my bad :)
Just had a talk with the manufacturers....
They don't offer any RB series turbo's at this point in time but they do have an RB25DET in the back.
What about some universal T25/T28, T3/T4 turbo's.... all are journal bearing and most externally gated.
Applications are from 1.5L to 4.0L engine applications.
What you guys think.... universal fit turbo's???
You wouldn't be able to offer anything different to what is for sale on the market at the moment!
Maybe with a $500 price tag and a 5 year warranty????????? but otherwise others are doing it, have the market, have the network and have the backup. Pity i thought this was actually going somewhere.
Edit: You need a difference, a market edge, not sure how or what, but thats for you to find.
mmm.... these would fit between the cheap China ones and Garret ect.
So you would say there is more interest in turbo's for the RB25 in the 250-260rwkw range?
Does anyone know of a brand of turbo not made in China but priced not far from them?
- Brendan
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
