ok guys im sorry for annoying the forum but i dont have a jack and no one around me know either, but does anyone know
if a kaaz 2.0 lsd out of a R32 will fit in my series 2 R33? Im seeing all this 6 bolt 5 bolt diff housing does any of this have anything
to do with me? As far as i know im told that my diff is a R200 and as long as its somthing like that i should be sweet,
if anyone can educate me on what my standard diff is and what can fit i'd be very great full.
Cheers guys
https://www.sau.com.au/forums/topic/357840-r33-series-2-diff-bolts/
You'll have to be more specific about the models of car you're talking about. Given you haven't supplied this info, I'll make an assumption you're talking about an R32 GTS-T and R33 GTS-T. They both use the same KAAZ diff centre (SAN2645), so it will be interchangeable between both R200 diff housings no problem. Whether you can put an R32 diff housing into an R33 vehicle is another thing though - might need to put in R33 side flanges to make it fit with your driveshafts.
When people talk about 5 and 6 bolt, they are referring to the bolt pattern of the side flanges where your driveshafts bolt on. R33 GTS-T have 5 bolt flanges. R32 GTS-T may use the 6 bolt (3x2) pattern, and this is why the R32 diff housing probably won't be a direct swap into an R33.
R32 GTSt uses 5x1 flanges like R33 GTSt, S13 uses 3x2 flanges and GTR uses 6x1.
S13 housing bolted in to my R32 but I have a funny feeling that R33 housings bolt up slightly differently (maybe bigger bolts at the front, seems to ring a bell).
Ahhh that's it, I remember why an R32 housing won't bolt directly in now...the mounting holes up front are smaller than an R33 diff. Backing plate is also different, however these can be swapped. Here is an R32 GTS-T diff:
Ah ok i apologize about not supplying the correct info, but yes Birds you are correct that the models are the GTS-T's, also i was referring to the diff centers
so yet again you provided me with more correct information.
I appreciate all the good info thats all i need boys cheers.
Cheers, Jace
For reference guys. The backing plate on 32 gtst housing has four bolts. 33 gtst has 2 larger bolts. The 33 gtst housing also has much bigger ears at the front of the housing. Both use 5 bolt half shafts in 5 x 1 comfiguration. The centers are essentially the same and can be swapped. How ever if ur putting the center out of say a mate 32 into your 33 then make sure you use your own crown wheel on his centre. Dont use his crown wheel. Crown wheel and pinion gear are a matched pair in all differentials so u should not going swapping crown wheel. It promotes noise and premature wear.
Cheers mate thats a helpful hint i otherwise would have never found out about haha good info
cheers, jace
This is true. However, R32 is 4.36:1 isn't it? You'd be nuts to swap to it anyway!
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
