where have people mounted gauges ???
What gauges?
I have
* boost gauge sitting just above the dash vent on the drivers side next to the A pillar.
* Exhaust temp gauge sitting to the right of the stereo just in front of the cigarette lighter. (made a custom mount from a piece of PVC tube)
* Greddy Informeter to the left of the main dash.
Can post a pic if you would like.
Cheers
Andy
Pretty much anywhere they can be seen from the driver's seat, lol. You'll find the fav spots are prob A pillar & inside the flip up (top) section above glove box. A lot of M35 owners are running GReddy Informeter touch which has configurable display so you don't need much else. Can mount this anywhere really. Mine is clipped onto a vent (use mobile phone holder) so can be removed easily.
Cheers, Leon.
What gauges?
I have
Cheers
Andy
Hey Andy, I'd be interested in seeing your custom EGT gauge.
Here you go Leon.
I just cut a 25mm wide section of 50mm PVC tube. It is really easy to manipulate with the heat guns. I used the actual gauge to push into the soft plastic and used a piece of wire on either end looped through the gaps to pull it around the gauge and then cooled with some water. Then flattened the other side. Paint black and done. :)
Hey Leon, how does that mobile phone holder work out?
Not too bad since being able to return my car (interior mainly) to stock without leaving too many remnants of my work is high on my list of priorities. The holder was the slimmest one I could find that would expand to the width of the GReddy unit.
I tried it on the drivers side first but not quite enogh room between dash cowling & raised centre. I laid some felt (or similar) inside the metal clips which slide over the vent slats so it wouldn't scratch them (anal, I know) and I had to use a small piece of black rubber to wedge the vent so it would stay put over bumps. It can't be seen & it stops the vent moving down from the weight hanging off it :happy: . Also, it is easy to slide out & put in the cubby below, to hide it from prying eyes if I am ever in a dodgy location like Sydney lol.
Andy, good work on the gauge holder you fashioned. That's a nice spot for it too. I hadn't worked out a way of mounting anything there successfully, so well done :thumbsup: .
What gauges?
I have
Cheers
Andy
yeah thats a good one might try that...... dont want to screw anything into the dash tho, so double sided tape it'll be!
just got a boost guage myself........ on idle its on 18 In. Hg (VAC) and in gear its 15 In. Hg (VAC) but on power it spikes to 18PSI and levels out to 15PSI is this correct ???
Edited by WAGON_BOY
Sounds a little high. Stock boost should be around 14-15psi on your Axis.
You have changed the dump pipe and done the exhaust?
Cheer
Andy
Cheer
Andy
ive done the dump pipe but the rest is getting replaced on friday......... i was reading i would get an overboosting issue after replacing the exhaust thats why i wanted to get the comparision before and after.
your referring to me,
I was only over boosting as i didnt enlarge the wastegate when I went to Stage 2 Sierra build on the turbo.. you shouldnt have any problems with your turbo..
ill be getting mine fixed this week sometime when I can be stuffed.
no worries :)
so why would i be sitting on 15PSI then???
do i need to go an buy a boost controller ??? :(
anyways ill put up pic's later of the new system :)
no worries :)
I think there's some variation in factory boost levels, eg my RS should "only" run at 12psi (or 12.6 to be exact) according to most sources, but my Pricol gauge had it at 14.x psi (dropping off to 13psi just before a gear change) on the stock exhaust. Now with full turbo back system it occasionally runs of the scale (15psi gauge only).
A typical boost controller won't let you run lower boost than standard. I think you will have to play with wastegate actuator springs or the like, to achieve that.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
