Lambchop With A Renault Axis Here...
the oil pan cover scrubbed out a few time but :whistling: gotta check the exhaust too hopefully that was safe!
was probably the cross member, it sits lower than most of the car......
Got the brakes machined today.......... feels so much better!!!
also its first oil and filter change and done the sparkies just for good measure.
only thing im waiting for now is my new rocker cover gasket cos its leaking like a sieve,
otherwise its all good :D
came across this and was wondering if anyone knew any more info on finding a guage holder that mounts in that exact possition where the TV unit goes...........
was hoping to hold 3X 2" 1/16 guages............
cheers :)
cheers :)
That's got to be custom.
I reckon you could roll a piece of sheet metal to fit there and mould some gauge cups in fairly easily.
cheers :)
start searching around the G35 forums.......are the defi gauges? If so there website my have that mount to suit.
ok im going to build myself a custom guage holder to fit 3 guages, ive already got boost and am wondering what the other 2 should be......
im thinking oil pressure and .................???..................... (water temp is already on the standard cluster so not sure if i really need that one)
other choices are oil temp, trans temp and air/fuel ratio..................... (have i missed any?)
or if the others arent to important i'll just make a 2 guage holder instead!!!
EGT and Trans temp would be my choices along with Boost.
where are you gonna put it. i might be interested in a 2 gauge holder with some$$ wanna make mine abit neater
yeah oil temp and trans would be alright.
Exhaust Gas Temp................. why do u say that ?
i've pulled out the box where the tv goes seeing as i dont have one.
will be sorta like this..........
EGT is very useful for a number of reasons.
1) In general driving you start to see how the ECU manages fuel and helps understand the whole car. ie, on the open road car leans right out and EGT is up around 600-700 degrees.
2) If you start (I think you already have) moding the car and the various components you can see the direct change you have made and in particular the change it makes to fueling which is very important to avoid leaning the motor.
I am sure there is more than this ... :)
How does EGT compare to AFR? reading wise...is one more accurate than the other?
I would think the AFR is a lot more accurate and if the device measuring is accurate enough will give you a much better result but I would imagine a very different cost.
Probably better than the EGT is the Wide band O2 sensor. Fester and more accurate and able to use for on road tuning.
yep make me one.
my TV is out of order as my emanage took over the dvd players spot.
pending price obviously
Myself and a panel beater mate are gonna try and put these into production, i'll make both dual and tripple guage holders............. fingers crossed!!!
 Share
