hell yeah it was lol
the emanage is cheaper and a proven product :P
Haha, yeah eManage is cheaper than the V-Pro... as it should be. It is, after all, a far lesser product.
V-Pro is not a proven product? You are crazy Bud.
These people
http://www.tunehouse.com.au/
or
http://www.belgarage.com.au/
I have never had any work done by either, and don't know the reputations, but have to say both don't look like a cheap option.
lol i guess the several emanage installs that have been running fine are crap compared to the no correctly running and tuned installs of the hks??
theo, even if you dont buy my emanage, get the emanage if all you want is to trim fuel and a bit of timing. craig was getting 280odd kw at all 4 wheels with his turbo and injectors.
Cam's was working?
Mine works, but I've got it removed until I get a proper tune. Car is booked in to get a suction pipe fabricated up next Saturday, then just need to fit all my bits, and get some injectors.
it was working, sort of. i think he had a few minor problems, possibly due to the fact it wasnt tuned
It was working, and well.
My issue was that I didn't replace the fuel filter which restricted fuel flow in the higher rpm (above 4500rpm) and that the tuner did not alter the throttle control map (so the throttle was initially quite boggy).
Was running very nicely after replacing the fuel filter and the adjustments I made to the throttle control map.
Also, I never said that the eManage is crap. The one that Scott bought was purchased from me a long time ago so I obviously thought they were pretty good.
Is it as good as the V-Pro? Not on your life.
if all youre looking for is a big number then im sure the fcon will get you that. but for an everday car the emanage will suffice!
theres no war, they are two different ECUs doing different tasks and really cant be compared
LOL, no war... I actually do like the eManage Ultimate as stated above, but I'd prefer if you stopped saying falsities like the Fcon wasn't running correctly in my car
Edited by iamhe77
Does to me. Works in my car. Removed pending tune.
Has to be done by April for a track day. Looking forward to seeing what numbers it pulls. Not looking forward to a busy couple of months of fitting bits >_<
lol those were your words! throttle response i believe
anyway, it doesnt matter now anyway does it? :)
Matters to me. I think you missed the part of my post where I said that my car... "Was running very nicely after replacing the fuel filter and the adjustments I made to the throttle control map."
Anyway, both ECU's work on an NM35. Just need a competent tuner I guess.
Haha, start the battle. :)
With only what, 6 cars tuned at the moment? One of them blown up, Craigs EMU has been removed, Jethro not allowed to drive, Cam cant drive = smashed (lol), Theres not many left on the road to battle...
What you forget is my e-manage is going back in with the new gearbox then a clean up tune......I'm not going out on standard injectors and ECU to beat the current record set by you........... I'm going to go out with all the right gear on the car and smash the record.....I've got about 12-14 weeks from memory to get it done!
Then its game on!
Edited by Jetwreck
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
