PN-Mad Posted March 17, 2012 Share Posted March 17, 2012 (edited) 1331896084[/url]' post='6277435']Ok I don't really understand this, so bear with me here... I take it what you're saying Alex is the duty of the injectors has an impact on the severity of the shifts? So if the injectors are at a low duty, you get sloppy shifts? So if I was going to stick with 98, I'd want to run standard or under 500cc injectors to keep them at 80-90% duty? First I'm hearing of all this, so just trying to get my head around it. You're running 600-odd cc Deatschwerks, right Alex? Hey mate. It's the base fuel schedule, not the injectors. But it's related. You want to run close to the capacity of the injector, but also with a margin of error. For example, if you have a 98 car running 1000cc but tuned to 220 kw or so, using 50% duty, then gearbox will be shit. It just won't run decent line pressure, because it does not reach the area in the table where the gearbox firms up. Now, if you run 1000cc and are on e85 and your are running big power, then you see 80% duty, a higher bfs and the car will access the good part of the table. Run a injector suitable for your power level. I'm on 600cc, don't know what duty cycle, but I'd guess about 60% at most. Sorry, another thing is the best way to do it would be to plug in your piggyback and with the stock injectors and boost check what base fuel schedule the cars sees at a stock k fuel multiplier. Then drop in injectors, wind up boost and try to get as close as possible to the original base fuel and retain safe tune. Note that your ecu will never change the calculated load table, don't think you could ever change it, but I don't now what effect that table has. Edited March 17, 2012 by PN-Mad Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6278065 Share on other sites More sharing options...
WAGON_BOY Posted May 5, 2012 Author Share Posted May 5, 2012 went on the dyno yesterday and this is what i got.......................... 173.7Kw @ 16PSI in 3rd gear. (couldn't handle 4th) Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6344846 Share on other sites More sharing options...
Commsman Posted May 6, 2012 Share Posted May 6, 2012 (edited) Nice! Does your car really run out to 6800 rpm or is there a slight calibration issue with that dyno & your car? And is your sig up to date? Is your 'tune' what the std ECU is giving you with the mods you have done, or do you have something else? Edited May 6, 2012 by Commsman Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6345175 Share on other sites More sharing options...
WAGON_BOY Posted May 6, 2012 Author Share Posted May 6, 2012 Nice! Does your car really run out to 6800 rpm or is there a slight calibration issue with that dyno & your car? And is your sig up to date? Is your 'tune' what the std ECU is giving you with the mods you have done, or do you have something else? standard ecu, and yes its up to date. i know that my ecu is different to yours because i dont have speed cut at 170km/h like everyone else so i'd assume AUTECH have played with a few things on the ECU. as for my redline i'll have to double check that, but yes he bounced it off the limiter LOL Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6345253 Share on other sites More sharing options...
Daleo Posted May 6, 2012 Share Posted May 6, 2012 standard ecu, and yes its up to date. i know that my ecu is different to yours because i dont have speed cut at 170km/h like everyone else so i'd assume AUTECH have played with a few things on the ECU. as for my redline i'll have to double check that, but yes he bounced it off the limiter LOL Sooo, errr; what'll she do mistah? On a private road of course... Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6345277 Share on other sites More sharing options...
WAGON_BOY Posted May 6, 2012 Author Share Posted May 6, 2012 here's the run, http://www.facebook....150828499794300 Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6345721 Share on other sites More sharing options...
WAGON_BOY Posted May 8, 2012 Author Share Posted May 8, 2012 so the air/fuel ratio looks to be alright..................... ??? need to get that wastegate actuator in there though!!! Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6348368 Share on other sites More sharing options...
WAGON_BOY Posted May 14, 2012 Author Share Posted May 14, 2012 as far as i have been lead to believe i didnt have an LSD but my nice 11's down the road (private road) tell me otherwise......... also yes Leon, my engine rev's till 6800RPM. Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6356122 Share on other sites More sharing options...
Dunc Posted May 14, 2012 Share Posted May 14, 2012 as far as i have been lead to believe i didnt have an LSD but my nice 11's down the road (private road) tell me otherwise......... also yes Leon, my engine rev's till 6800RPM. Got a VIN? Run it through fast / EPCData ( http://nissan.epcdata.ru/stagea/ ) Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6356194 Share on other sites More sharing options...
Daleo Posted May 14, 2012 Share Posted May 14, 2012 Got a VIN? Run it through fast / EPCData ( http://nissan.epcdata.ru/stagea/ ) I punched mine in; and it doesn't specifically say that it has an LSD (which it does), but if you click on "Final Drive, Rear" it displays the exploded diagram of the Viscous LSD diff assy. Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6356236 Share on other sites More sharing options...
PN-Mad Posted May 14, 2012 Share Posted May 14, 2012 Just tried mine, shows a single spinner in the diagram. I've used this before but never figured out this function. Thanks Dunc. Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6356254 Share on other sites More sharing options...
Daleo Posted May 14, 2012 Share Posted May 14, 2012 Just tried mine, shows a single spinner in the diagram. I've used this before but never figured out this function. Thanks Dunc. You'd better get in touch with them, to let them know they need to update your stats with a f**k off big turbo! Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6356261 Share on other sites More sharing options...
Dunc Posted May 14, 2012 Share Posted May 14, 2012 I punched mine in; and it doesn't specifically say that it has an LSD (which it does), but if you click on "Final Drive, Rear" it displays the exploded diagram of the Viscous LSD diff assy. You should also get 'Spec Code: DIFF6' which, if you hover over, says 'Viscous LSD' (or at least thats what mine does) Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6356264 Share on other sites More sharing options...
Daleo Posted May 14, 2012 Share Posted May 14, 2012 You should also get 'Spec Code: DIFF6' which, if you hover over, says 'Viscous LSD' (or at least thats what mine does) Only shows ETC2 in the spec code. Oh well. Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6356281 Share on other sites More sharing options...
scotty nm35 Posted May 14, 2012 Share Posted May 14, 2012 I had better get the shopping list off to Nissan so they can update mine on Fast. Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6356402 Share on other sites More sharing options...
WAGON_BOY Posted May 15, 2012 Author Share Posted May 15, 2012 it show's 2 pictures of the rear diff and the second one says LSD..... Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6357272 Share on other sites More sharing options...
PN-Mad Posted May 15, 2012 Share Posted May 15, 2012 Pretty easy way to tell - stick your jack under the diff, lift, and turn a wheel. The other side of my car turns the oppo way, Craigs with the LSD turns the same way. You can do 11-sies with an open, but if you have a hint of lock on, it'll do the inside. Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6357288 Share on other sites More sharing options...
WAGON_BOY Posted May 24, 2012 Author Share Posted May 24, 2012 throwing some idea's together for modifing my axis front bar............ basically steal the R35 grill insert and make my own version of that to suit the axis lines and steal the audi's design of the side air vent sections and marry them all together.......... i've got a vision in my head so i know what it's gonna look like but putting it on paper is another story LOL Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6369873 Share on other sites More sharing options...
PN-Mad Posted May 24, 2012 Share Posted May 24, 2012 Needs moar high flow, FCon, and tune before body kit! Maybe draw a pic? I'm having trouble imagining. Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6369909 Share on other sites More sharing options...
iamhe77 Posted May 25, 2012 Share Posted May 25, 2012 You know if you just chopped the bling lower sections out, there are two massive air ducts there for coolers. Link to comment https://www.sau.com.au/forums/topic/357886-lambchop-with-a-renault-axis-here/page/28/#findComment-6370441 Share on other sites More sharing options...
