Lambchop With A Renault Axis Here...
thanks to Dale's effort in getting me the swaybars etc i've now got them in but im going to have to spend some time tweaking it, although its nice and firm ive had to back the shock's down and now i think im goin to have bigger prolblems with bottoming out in dips etc.
ahwell thats the fun part i guess trying to find the settings to make it handle nice allround.
  • 4 weeks later...
not much to update atm but i am getting my rims repaired after an altercation with a roundabout island which i lost LOL i swear it jumped out at me
and still waiting on my new bonnet and rear chassis brace.
still wondering if i should bother putting the F-con in yet.......... it would help because i am getting a fair bit of overfueling especially seeing at the BOV is venting to astmosphere and on gear change / lift of throttle i get some good backfires :)
Here we go current mod's to date.
Power Duct and BMC Airfilter, Scotty's Dump Pipe, Fully Custom 3" Stainless Steel Xforce Exhaust, Phenolic Intake Spacer, HDi Intercooler, Turbosmart Dual port BOV, Dale's custom 2.5" Sutcion Pipe and Scotty's Wastegate Actuator.
Weird graph with the converter locking up on the original run and staying locked up after, did you cut any wires or is that a result of playing with settings?
How does she drive anyway? I'm sure you feel the torque drop off after 5k... Time for a highflow? :whistling:
still need to find out why im dropping off on boost, its ever since i changed all the vacuum hoses ahwell im happy any way might save the turbo a bit longer
Boost will always drop off a little due to the pressure in the manifold skyrocketing and blowing the puck open, the spring only helps so much. Do you have a controller?
the graphs are different at the bottom due to different throttle application.
we disconnected the manual boost T and are running it straight from the BOV to the Wastegate.
its a bit hard to describe but u can feel the extra power but overall the car is alot tamer than before, its very strong down low and very driveable on the freeway.
the car just sounds healthier has a nice crisp note to it now and damn does that suction pipe make some noise!!!
the cars just so different to drive i'll have to see how it goes over the next few weeks (mainly only use it on the weekend)
anyways just finished mounting the computer in the dash so gonna go out and drive it!!!!!!
Nice Theo.
Glad you find it nice and smooth to drive. You'll have some fun at the drags I think. A programmable boost controller will take care of that drop off. Does the ECU have that function?
Are you still running off the AFM sensor? What Volts did you get up to?
Did you get a chance to over lay with my 3rd gear pull?
 Share
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
