i got the instruction manual for the wideband i want to make sure it's going to be useful before i get it.
"The Bar Graph Display (BGD) Range Setting Mode allows you to fine tune the resolution of this instrument for your specific application. With upper and lower set point adjustability, you can set the BGD to utilize the exact range that the engine / vehicle operates within and see exactly how rich or lean you are running in relation to your current set up and tune. Adjusting your BGD limits also adjusts the scaling of the 0-4v data logger output supplied from the gauge. The selected low set point of the BGD Range becomes the 0v value of the data logger output. The selected high set point of the BGD Range becomes the 4v value of the data logger output. Whenever you change these points, the instrument adjusts the data logger output so that the 0-4v signal is always linear between your chosen set points. "
Looks pretty good Theo. WOT input looks interesting, mine doesn't have that. Although the Innovate's have a built in data logger, whereas the Auto Meter seems to want one connected (which is probably the output you'd use for the F-con).
But at the end of the day it depends on whether the tuner wants to use it constantly, or whether you just use one of those ones you can stick in the tailpipe for the day.
My dyno has its own wideband that logs afr to the graph.
I have 2 standalone widebands that can be used for datalogging or roadtuning.
I recommend putting the wideband in for piece of mind, can then see if u have a lean out etc due to fuel surge or fuel pump failures etc
Howd it go today Theo :)
So all ur worry was a false alarm, the 02 sensor reading in the cypher software the Alex was reading from has no bearing on what the actual AFR's are. Tune was fine except for the 1 area which u heard a ping at low rpm high load which was very difficult to replicate on the dyno due to the auto but i found it and fixed it.
Ps, nice single pegger skid when u left :P
Very interesting today Jez- so we know stock ECU > Theos aftermarket computer> motor.
And I can only read what the stockie puts out.
Had a great run coming back down the old Pac- volvo convoy.
Nice :)
Yeah was very weird, especially how much difference there was in the ignition timing output from his aftermarket ecu to ur software
So second tune and no gains? C'mon Theo, slap a Hypergear in there... :P
All the stock ecu does now Alex is run the throttle and cams, nothing else has a bearing other than to keep the MIL away. I have no idea what signals the Fcon sends back to keep it happy but whatever it is, thank you mr HKS.
Jez also found some little parts of the pre-loaded tune that were no so good - and sorted them out.
I've got some logs from the power runs. Might load them if I can be stuffed
That's why I wouldn't use maps designed for other cars, you will always end up chasing gremlins in the tune imo.
Post them up Alex, I would be interested to learn what the Fcon is doing to the stock ecu and that may hold the key. If I end up going down the Link G4 route I may need the same signal bending output maps... The manual transmission will open up a world of possibilities. ;)
Honestly i wouldnt trust the log files as even the timing etc is way off
Exactly right.
As I said it goes Stock ECU > aftermarket>engine.
So Ign timing is not correct for the engine, but other things like Cams, AFM, and BFS are all able to be seen accurately.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
