finally after getting the wrong coloured facia its all back together and I have a radio again!!!
I've put up a thread with the wiring colour codes in case anyone else needs to replace theirs, cant seem to link if for some reason though.....
Http://www.skylinesaustralia.com.forums/topic/437160-m35mradio-replacement-wiring-colour-codes/
Finally got my go-pro footage from the SAU track day back on the 29th of Oct 2013 @ SMSP south circuit.
here was my last run where I got a free run with no traffic and managed 3 awesome laps
2x 1:09's and a 1:10.
http://www.youtube.com/watch?v=dcvL4eyt1qY
best of the day was a 1:09.14 with consistent 1:09's all day long :)
starting to get p*ssed off with all the little niggly bits, so I'm going to try and sort them out before I loos my sh*t:
1) redo my headlights
2) need to get the bonnet struts as the fibreglass bonnet is to flimsy to support by the stock arm and so the AXIS bonnet add on is starting to fall off.
3) this radio change over has been a massive PITA, hate the aftermarket A/C buttons, and seems as though I've blown part of the BCM that controls interior lights, tail lights and parker lights so now I need to replace the BCM which seems more or a PITA than it should be.
4) need to tidy up my gauges as it looks like sh*t so going to have to pull my finger out and make a fibreglass one!!!
5) should probably replace my drive belts and fuel filter I'm guessing they are well over due!!!
6) need to get this window washer bottle cos its a PITA having a dirty window all the time that I cant clean whilst I'm out
once all this is done I might feel better cos atm I'm getting annoyed my cars turning to sh*t because of neglect!!!
ah well that's my rant for the week!!! :)
I still have no 6 in pieces. :domokun:
I'll get cracking.
You makin a washer bottle Dale?
I did a cardboard mock up about a billion years ago for Theo; will use the OEM filler neck, and the side also acts an air guide for his oil cooler.
I have all the sheet guillotined and bent, neck made, then we had another kid. :rolleyes: I need to machine some bosses for the pumps to push through then get off my arse & weld it.
I'm so busy at work now, I barely get time to do my paperwork in the extra hour I work on top of my 12hr shift. Weekends used to be fab time; not anymore.
It might hold a litre of water, with the neck volume added; a little more.
It's something I was interested to make for myself, sounds way too complicated to make multiples of though.
I would love to get a second oil cooler in there... Not like you need 40L of washer fluid anyway. :P
I have the advantage of being able to use my cardboard mock up for templates; I'll see what this one turns out like.
A litre odd would last long enough.
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
