i honestly wouldnt though, it would ruin the look of the axis, imo anyway..
it could well ruin it but i think the extra air flow will be worth it................. any other options, maybe some round ones :P HAHA
yeah the grill is bigger but the lower section isnt all that big..........
the yellow section is open for air flow but the intercooler is in the red section so i thought i'd pop in the vents where the black section is for even more airflow...........
Get a bigger intercooler? :P
i went and bought a B&M trans-cooler (70264) this morning and fitted it already :D
ive done it the easiest way possible for now untill i do the intercooler cos i'll probly have to move it then.
just a quick one about tires and what i should be running.............
currently i have 245/40/18's which is the correct size acording to the AXIS broucher that says they come with 225/45/18's so that means i should run a 245/30/20........... according to my TOMTOM this is 10% out at 110 it says im doing 100.
so then in the owners manual it says to run a 225/55/18 which is the size compairable to what the normal M35's run so that means i need a 245/40/20 and then hopefully my speedo will be correct acording to the TOMTOM????????
cheers guys i just dont know which tyre i should be basing it off to get my speedo correct without finding out the hard way with a speeding ticket!!!
245/30/20 Nexen N3000's.............. dont really know how good they are but i'll soon find out i was told they should be better than the federal 595's i had on there but not as soft as a Yoki or a P-zero.
"Ultra High Performance Driving
  • Directional wide aqua groove design
  • Arrow center rib design-High speed driving performance
  • Shoulder design-Improved cornering stability
  • Aggressive type lateral grooves-Resists hydroplaning
  • W & Y - speed rated
  • UTQG 340AA"
Big thanks to Craig, Andy for putting in the shift kit and also Ian for the advice tonight :worship:
and the trans-cooler is working too :D
makes a difference thats for sure, full throttle shifts are great but the cruising shifts are a bit harsh IMO. :)
Lucky bugger!:nyaanyaa:
Mine goes in tomorrow night.:banana:
Edited by Daleo
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
