245/30/20 Nexen N3000's.............. dont really know how good they are but i'll soon find out i was told they should be better than the federal 595's i had on there but not as soft as a Yoki or a P-zero.
"Ultra High Performance Driving
  • Directional wide aqua groove design
  • Arrow center rib design-High speed driving performance
  • Shoulder design-Improved cornering stability
  • Aggressive type lateral grooves-Resists hydroplaning
  • W & Y - speed rated
  • UTQG 340AA"
better than federals? lol nexens are as good as nankangs, i had them in the supra for less grip so i could rip serious skids yo
thiis is 3 year ago mate, could be improved now, but thats why I bought them, cheap, hard tire that didnt wear quickly, was perfect for skid pans.. but for everyday drivng they werent to bad, im comparison to pzeros or feds? no where near... imo anyway
I've used 595 SS on the front of my 180sx and found them very average. I used them on the track drifting and suffered understeer all the time. I got a price today for a kumho ku31 in a 245/45-18 for $266, waiting on a price tomorrow for a nexen n6000 in same size out of interest.
Edited by slippylotion
i just got some Achilles for my 31
235/45/r17 for $107, apparently not bad at all (this is only on the rear) but apparently popular with the drifters because they have a bit of grip and last pretty well
Yeah Achilles sponsor the Monster/Nismo 350Z in Stadium Drift now.
A few of the guys I've spoken to prefer the Federals, because they get more grip for the steer tyres and last longer. A lot of those cheap tyres last 1-2 runs :domokun:
lol yeah didnt click on the day until i looked up the pic's and realised the tread pattern was different.
BUT it seems these are made in the same factory as the continental tyres
just wish they wouldve told me thats all!!!
the new IC is in and ready to go, had to move the trans cooler like i thought and also i made a few mods to the grill and front bar :D
bring on the cruise on sunday!!!!!!
my first problem with the car, its intermitantly idleing really high, like 1500rpm in "drive" and 2500 in nuetral.
noticed i had wired the thermo fan up backwards but the car didnt overheat.
as far as i can tell by the boost gauge its still on the correct vacuum at normal idle.
any idea's i need to get this sorted before the starlight charrity cruise on sunday!!!! :(
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
