What's the story behind the car with the truck exhaust? :sick: It must be a joke...
its actually a pretty common thing in some groups in japan!!! alot of cars are styled just like that celica..............
Haha, I love the use of the term 'styled'. Like trailer parks sometimes get 'styled' by tornados :laugh:.
Wouldn't say it was pretty common though............ - exhaust is derived from the JDM trend 'Bosozoku style' and the flares are commonly combined with what the Japanese call 'low ride' and is known as 'Shakotan style'...
Edited by prince_skyline
i bought a trans temp guage hoping to have a look under the car tomorrow for a spot to install the prob in the sump or maybe in the outlet fluid line to the cooler.............
I'd be looking to braze/weld a bung into the sump. Best spot for it.:thumbsup: In the fluid line; you won't know what's going on when in manual mode (the GB isolates the cooler circuit) which is probably when you need it the most.
I've been idly wondering about the worth of welding a series of bungs into the trans sump (or a 1/2"plate tapped with BSP threads) one for temp gauge, one for a temp switch and a couple for a low pressure electric pump fed external cooler.
This would get around the issue of the gearbox bypassing the cooler then in manual tiptronic mode (when it's needed most). I know people reliably use small low pressure VDO pumps to scavenge and return oil to the sump in turbo setups where the drains are below sump level.
That said; it might be a bit more effort and expanse than is absolutely necessary...
An interesting thread for some detail; http://www.rbracing-rsr.com/oilsystems.htm
Edited by Daleo
exactly!!!! some people might think its a waste of time but i think its important seeing as i have it in manual mode 90% of the time and i dont want to destroy the fluid or the GB.
yeah might aswell get 4 bungs put in cant hurt really.
If you drive around in manual a lot why don't you try Aaron and Scotty's unlock mod? Its on here somewhere if you search, or I've got it bookmarked at home. Makes the cooler work all the time, even when it's in manual mode.
I'm looking at doing it when I get the shift kit and trans cooler in.
Doesn't that unlock the converter too?
I'd just like to be able to run the cooler when in manual mode with the converter locked. I'm pretty sure the unlock mod is pretty devastating for fuel economy too...
I'd heard that from Aaron, & it would want to be a great mod before I decided to go backwards on fuel economy. My ethos is always 'more for less', & I'm not sure that mod fits the job description.
yeah there's no way im doing wire cut mods........ and yeah the idea of the converter always being open and loosing power and fuel ecconomy its not worth it!!!!
Dale's idea with an external feed/pump to a cooler is probly the best way of doing it!!!
I don't think you lose power as such; because the converter is open, it'll actually build boost quicker because it flares a little.
The only issues I can see are the obvious necessity of a $250 pump & attendant lines, and a cooler; that's before you factor in modifying the sump with internal pick up and returns at opposite ends, to ensure you're cooling effectively, not just re-cooling the oil that just came out of the return.
Also, it's added complication when a decent sized cooler and a thermostat will probably do the job 90% of the time.
Tell me if I'm wrong, but surely driving in manual mode for a few minutes and then chucking it back in D would be fine? Let everything cool off and then have some fun again?
I fairly regularly drop it back into 2nd to drive through a roundabout and then chuck it back into D. *shrugs*
It depends on load I guess.....I know when my car was stock it was not a huge issue going across the gate all the time but I never stayed there more than a couple of minutes. But... with a little bit of HP/NM the standard GB cooks pretty quickly(better once the HD2 kit is done)........a couple of minutes wont hurt though imo......best idea is to knock it across the gate after the second gear shift.......with the standard turbo revving the thing to 6,500rpm is a waist anyway + your already doing over 110km's.
Mind you Paul you will find after you do a couple of the VB's a difference in oil colour between those who drive across the gate all the time and those that don't.
Edited by Jetwreck
I was thinking of drawing up a simple mod to allow the ATF to pump thru the cooler whilst in manual mode, BUT switch back to standard when in D, thus not buggering my exceptional fuel economy. I'll work on this soon, maybe this weekend, & post some results if anyone is interested.
Craig, I wouldn't have though there'd be that much difference in fluid colour (I'm guessing some looked a bit 'burnt'?) so I will be using manual mode sparingly until I sort something.
im interested. Would this be a wiring mod or require any additional parts beyond a switch/wires??
Maybe a relay so it happens automatically, but it shouldn't cost more than pocket change. I haven't had more than a cursory glance, but noticed a few things when reading up on speed wires for the cruise control.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
