Lambchop With A Renault Axis Here...
hell yeah it was lol
the emanage is cheaper and a proven product :P
Haha, yeah eManage is cheaper than the V-Pro... as it should be. It is, after all, a far lesser product.
V-Pro is not a proven product? You are crazy Bud.
lol i guess the several emanage installs that have been running fine are crap compared to the no correctly running and tuned installs of the hks??
theo, even if you dont buy my emanage, get the emanage if all you want is to trim fuel and a bit of timing. craig was getting 280odd kw at all 4 wheels with his turbo and injectors.
Cam's was working?
Mine works, but I've got it removed until I get a proper tune. Car is booked in to get a suction pipe fabricated up next Saturday, then just need to fit all my bits, and get some injectors.
it was working, sort of. i think he had a few minor problems, possibly due to the fact it wasnt tuned
It was working, and well.
My issue was that I didn't replace the fuel filter which restricted fuel flow in the higher rpm (above 4500rpm) and that the tuner did not alter the throttle control map (so the throttle was initially quite boggy).
Was running very nicely after replacing the fuel filter and the adjustments I made to the throttle control map.
Also, I never said that the eManage is crap. The one that Scott bought was purchased from me a long time ago so I obviously thought they were pretty good.
Is it as good as the V-Pro? Not on your life.
if all youre looking for is a big number then im sure the fcon will get you that. but for an everday car the emanage will suffice!
theres no war, they are two different ECUs doing different tasks and really cant be compared
LOL, no war... I actually do like the eManage Ultimate as stated above, but I'd prefer if you stopped saying falsities like the Fcon wasn't running correctly in my car
Edited by iamhe77
Does to me. Works in my car. Removed pending tune.
Has to be done by April for a track day. Looking forward to seeing what numbers it pulls. Not looking forward to a busy couple of months of fitting bits >_<
lol those were your words! throttle response i believe
anyway, it doesnt matter now anyway does it? :)
Matters to me. I think you missed the part of my post where I said that my car... "Was running very nicely after replacing the fuel filter and the adjustments I made to the throttle control map."
Anyway, both ECU's work on an NM35. Just need a competent tuner I guess.
Haha, start the battle. :)
With only what, 6 cars tuned at the moment? One of them blown up, Craigs EMU has been removed, Jethro not allowed to drive, Cam cant drive = smashed (lol), Theres not many left on the road to battle...
What you forget is my e-manage is going back in with the new gearbox then a clean up tune......I'm not going out on standard injectors and ECU to beat the current record set by you........... I'm going to go out with all the right gear on the car and smash the record.....I've got about 12-14 weeks from memory to get it done!
Then its game on!
Edited by Jetwreck
 Share
    • With my pre/power I use a remote trigger cable(3.5mm jack each end). I turn tv on, it turns both on via ARC. Or, just the pre with the remote or its streaming software, turns on both. Not that difficult at all. Obviously,  you would also want to actually update/upgrade over other factors in your life(bills, family, other hobbies, etc)
    • Yeah, nightfall was very "meh". And I'm crap at pvp, so feels like everyone has cheats(it's just my lack of skill). Final shape has been pretty good. New raid and dungeon are pretty good. If you want to give it a go, probably wait until it's on sale. But, as usual, most of it feels very familiar.
    • This morning was Kingswood's Microscopic Wars. It is the album's 10 year anniversary this year and we went to see them play the whole album as a special show a couple of months back. Was pretty spectacular.
    • Yeah I would like to try and get a ADM car to reduce issues with insurance. I've decided if I end up getting this car I will set it up to be a sleeper build, leave it looking stock/dad spec on the outside I wonder if you can just drop in the 400r/Red/Z ECU or better still use a flashing tool to copy the map off one. Backup the factory map and then flash the 400hp cars onto the 300hp cars ECU?
    • Nah, yeah, nah. Speakers have a nominal impedance of 8 ohm that looks more like 6.4 ohm when measured. The receiver's amplifiers (all channels) are all rated to 6 ohm (I think, it's been a long time since I cared). The real problem is that many modern class D amps have aggressive protection circuitry that cuts off the fun if they think too much current is being drawn. And with my speakers having series crossovers, as opposed to more typical parallel crossovers, and big TL enclosures, they can certainly dip down to lower impedances at some frequencies and that easily triggers the protection. Pioneer receivers are somewhat famous for it, but even Denon, Onkyo, et al, all have many complaints against them across various models. It only does it when listening to music at high levels. You have to be putting your ears at risk to do it. But sometimes I want to do that. If I was serious about using it as a listening room I'd simply upgrade the amp for the front pair to a nice Rotel or something, and just use the receiver for signal handling and processing - although that would be a bit of a pain in the arse too. Have to switch on more shit, pre-amp volume vs main amp volume, etc etc.
