here are 2 options......... my drawing skill are rather ordinary but u get the idea, preportions will depend on the reo behind the bar etc
either its a GTR style grill or a Stagea style grill........ for the top section, the lower will be GTR spec and the sides will be RS6 spec
Wagzilla!
Icwatyoudidthere. Drawing skills much better than mine. I think the lower one is better, but I'm far from a style expert! I think it would look less gape-y. Maybe some little vents in the bottom sides to vent things like tranny coolers?
Haha, I think I like the top one.
The angle of those lines in the lower one make me think HSV (VY specifically) plus the gently lines work with the rounded disposition of headlights and might flow a little better with the rest of the car.
Nice drawings though :)
I think the drawing is the least of your worries. Nice job on those btw.
Actually blending it together in the flesh (plastic?) is going to be the real challenge. I'd like to see that! Should be an original though, if it gets done.
yeah the side vents will definately be utilised for coolers,
the finished product will definately look nothing like a HSV!!!
as far as trying to get the plastic to blend in isnt a problem as it will all be fibreglass and just painted black.
but yes i like a good challenge i have big idea's but achieving them is the hard parts LOL, still havent completed my guage cluster HAHA
412226_10150912402669300_562669299_9658685_2104652292_o.jpgThis is what it would look like with thr GTR centre (exact replica, to scale) with the axis chrome chopped out of the lower sides.
Looks good but I can't help but think of the mitsubishi 380 when I look at it. Obviously it should look much better actually done
your dreaming Aaron............ how does it :P
i dont know lol even after i compare the two they look nothing alike.. as i said though it would look awesome!
Don't worry about him Theo.
Like we take notice of someone driving a bright orange turd!
BRTky.jpg?1320962111
seeing as the car's off the road for about 2 weeks i got drunk and this happened........
FYP Mate.
Blue... suppose it matches the calipers now :P
Oh, didn't see that you pulled all the shiny stuff out too. Going to put Leb mesh in?
installed my Mishimoto radiator today and i gotta say for the price $560 delivered i gotta say im not all that happy with it as far as mounting and clearance (the a/c condencer mounts to it also) even though i understand its for a G35 not a M35, also the trans section cannot be used because of the f**ked up size and thread thats on there, so i might have to look at the american market for fittings to suit.
as far as build quality and cooling capacity it is great.
so unfortunately im a bit dissiapointed but it should do a good job, and now i have to custom mount 2x 14" thermo fans to it. (you can keep the stock clutch fan though)
Did you try Pirtek for those barbs I told you about for the trans?
They seem to be working OK on Craigs car. Might be worth a shot- only $6 or something each, before you go to the states.
Na Alex i didnt try Pirtek cos Craig said they were sh*t fittings anyway.
oks cheers Scotty.
was running without the shroud around the clutch fan for a day and now i know that the thermo fan on the front works LOL cos everytime i stopped it would kick in so now i've put the shroud back on and it should run properly again but atleast i know that fan works.......... also thinking of putting a fan on the transcooler just in case, i've got it sitting infront of the passengers side wheel now...... not to sure how good the ventilation off the back of it is.
Yeah, they weren't crash hot, but was the first thing I could put my hand on that would work.
When you find something that works let me know, cause I need some too!
If your worried about the cooler flow, you could always cut a hole in the back of that plastic wheel arch and mesh it. That would flow ok I guess but not pretty. Otherwise maybe move it up above the intercooler where the other guys run it. Do you have something there already?
I'm sort of luck with my poor mans 1/2 size intercooler. There was plenty of space.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
