thanks to Dale's effort in getting me the swaybars etc i've now got them in but im going to have to spend some time tweaking it, although its nice and firm ive had to back the shock's down and now i think im goin to have bigger prolblems with bottoming out in dips etc.
ahwell thats the fun part i guess trying to find the settings to make it handle nice allround.
  • 4 weeks later...
not much to update atm but i am getting my rims repaired after an altercation with a roundabout island which i lost LOL i swear it jumped out at me
and still waiting on my new bonnet and rear chassis brace.
still wondering if i should bother putting the F-con in yet.......... it would help because i am getting a fair bit of overfueling especially seeing at the BOV is venting to astmosphere and on gear change / lift of throttle i get some good backfires :)
Nice one! Let me know how you go!
My harness is on its way back and I'll be getting it tuned as soon as my EVC6 turns up... Want to replace the factory solenoid before tuning.
Here we go current mod's to date.
Power Duct and BMC Airfilter, Scotty's Dump Pipe, Fully Custom 3" Stainless Steel Xforce Exhaust, Phenolic Intake Spacer, HDi Intercooler, Turbosmart Dual port BOV, Dale's custom 2.5" Sutcion Pipe and Scotty's Wastegate Actuator.
Weird graph with the converter locking up on the original run and staying locked up after, did you cut any wires or is that a result of playing with settings?
How does she drive anyway? I'm sure you feel the torque drop off after 5k... Time for a highflow? :whistling:
still need to find out why im dropping off on boost, its ever since i changed all the vacuum hoses ahwell im happy any way might save the turbo a bit longer
Boost will always drop off a little due to the pressure in the manifold skyrocketing and blowing the puck open, the spring only helps so much. Do you have a controller?
the graphs are different at the bottom due to different throttle application.
we disconnected the manual boost T and are running it straight from the BOV to the Wastegate.
its a bit hard to describe but u can feel the extra power but overall the car is alot tamer than before, its very strong down low and very driveable on the freeway.
the car just sounds healthier has a nice crisp note to it now and damn does that suction pipe make some noise!!!
the cars just so different to drive i'll have to see how it goes over the next few weeks (mainly only use it on the weekend)
anyways just finished mounting the computer in the dash so gonna go out and drive it!!!!!!
ohh and no i havent got any extra sensor's they'll go on once i do the highflow etc etc
i'll probly only get the map/temp sensor and look into wiring up a EGT.
Nice Theo.
Glad you find it nice and smooth to drive. You'll have some fun at the drags I think. A programmable boost controller will take care of that drop off. Does the ECU have that function?
Are you still running off the AFM sensor? What Volts did you get up to?
Did you get a chance to over lay with my 3rd gear pull?
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
