OK any of the guys running F-Con's might be able to help me out and of course Scotty...........
i might aswell quote whats been said its a it easier, but any ways Alex did a cipher log on my car and then i passed on the details to Jez and the question is as follows:
Alex: "there seems to be a problem with the ECUs AFR correction, because it is cycling to each end of the ability to % correct. To my knowledge this is usually caused by the fueling map not being accurate enough in the low range/stoich range. You can try disconnecting the O2 sensor, and see how it drives, but let Jez know, and I'm sure he'll be able to touch it up a bit. If it gets really bad, just disconnect the HKS and run the stock ecu."
Jez: "Have u spoken to Scott? He mentioned that the f con is designed for 350z and the 02 sensors cant be used accurately or something along those lines. Have a chat to him but of course we can check it on the dyno or road with my wideband"
cheers Theo.
Have you got a Wideband Theo?
Might be worth connecting the output of it to the F-con for feedback.
Not sure about what Jez said about the O2 sensor, never heard that myself, but I'm connecting the wideband to the F-con to cover that base.
Just disconnect the feedback for now, although you will need to switch it off in the software. I have never had my o2 feedback working, there is no narrowband sensor in my exhaust. I was planning to do as Ryan said, hook the wideband in to the fcon. Do we have information on which input to use ect? It's been a while since I looked at the wiring diagram...
This is what I was able to scrounge in my files...
Wideband A/F 5V - GCC Ignition Signal Input 16
Wideband A/F GND - GCC Ignition Analog GND
Fuel 2: Wideband Input
AFR 1 Feedback Map: Fuel Trim Map
AFR 2 Feedback Map: OFF
AFR Feedback Start Time: 60
AFR Feedback Cycle Time: 100 msec
AFR Feedback Volume: 1.00
AFR Feedback ECT (low): 80 C
AFR Feedback ECT (high): 100 C
NOTE: To enable Target AFR tuning, AFR mask table needs "1" setting in enable zone.
NOTE: Once Target AFR tuning is done, set AFR 1 Feedback Map to "OFF"
Not sure if that's useful, mine is setup a little different.
$444.00 for a Autometer 3378
Sport-Comp Air/Fuel Ratio Pro Gauge
2-1/16", Digital, Wideband, Range: AFR or LAMBDA
does that price sound about right and is it a good unit?
would like to stick to this one as it will match the rest of my gauges but if its not suitable or a rip off i might reconsider.
edit:
  • Includes 8 ft. tubing or wiring harness.
  • LED digital display.
  • 0-4v data output feed for ECU, data acquisition unit, or Laptop tuning
  • Auto-Dimming gauge brightness feature
  • Includes custom tuned .1 AFR Resolution Bosch LSU4.2 Sensor
  • Display data in Lambda or numerical A/F ratio
  • User programmable range
  • Peak recall/memory
  • 10:1 to 20:1 AFR Range for Gasoline Applications
  • Adjustable for Alternate Fuel Types (Ethanol, Methanol, Propane, CNG)
  • 6:1 to 18:1 AFR Range for Alternate Fuel Types
  • User Programmable Warning Function
  • This product has no provision for dial illumination/back lighting
Edited by WAGON_BOY
hhmmm seems as though my stock computer has overridden and tuned itself to a bad state (its been in about 2000km)
noticed pinging today, and once again the cell light came on, but this time when cruising down the highway.
the exhaust smells like unburnt fuel and the engine oil reaks of petrol, so im not happy but we'll get it sorted.
so i think its time to sort out the O2 sensor or f*ck it off and like you guys have said get a wideband and connect it to the f-con.
any other idea's welcome.
Edited by WAGON_BOY
it only ping'ed cos i was being a knob held it in 4th going up a steep hill at 90km/h i shouldn't have pushed it and/or dropped it down a gear and it probably would've been alright i guess.
but it makes me wonder if it's done it more often and i haven't noticed cos i've had the radio on.
Not worth the risk I don't think, so cheap insurance. You can log it all too.
I don't think Scott had issues with the stock ECU retuning itself though?
I'll be able to tell you more in a few weeks when I get it in. Although mine will be different, as I've got the extra sensors.
Get a wideband with a programmable narrowband output.
You can then wire the narrowband output into where the O2 sensor was, and the wideband output into the fcon.
That is the sensor plug, you would need to turn off o2 feedback in the fcon though or the code will show.
If it is pinking you will need to get timing backed out in that cell. Doesn't sound like a safe tune unfortunately. Take it back and get it sorted asap. Bad pinking is similar to hitting the edge of the piston with a mallot, the engine won't take it for long at that power level.
I suspect the ping was due to it being too lean. Was like cycling before, adding and taking fuel. If it was taking fuel out up the hill, then it would increase the risk of ping. Unplug O2, reset ecu, and see what it does. Shouldn't ping in high load/rpm because it shouldn't be using the O2 correction.
I think the tune is safe, but it's the ecu having trouble with the O2 sensor. The tune really has no bearing on that. If it doesn't work, then just as Scotty said, move the fuel target to 15:1 and that'll stop the ecu using the O2.
is there any way to stop the fault code 0135 popping up cos the O2 sensor is unplugged ?
This ^^ is excellent advice!
If you replace your narrowband O2 sensor with a wideband one to do what Ryan suggested above, the CEL will continue to pop up, not because you don't have a narrowband signal going to the ECU (you will have from your wideband), but because the ECU can't see the O2 sensor' heating circuit.
The fix is either a) install your wideband sensor further down the pipe, just before the cat (like recommended by many suppliers) & leave your factory narrowband sensor still plugged in. The signal circuit will be disconnected from the ECU so won't do diddly to your tune.
Or b) replace your factory O2 with the wideband one and put a very large (10W) resistor across the heating circuit (near that green plug that you pictured) & that will fool the ECU into thinking the sensor is still there. I'll have to check what resistance it should be, but somewhere around 10 ohms is what I'm thinking.
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
