i got the instruction manual for the wideband i want to make sure it's going to be useful before i get it.
"The Bar Graph Display (BGD) Range Setting Mode allows you to fine tune the resolution of this instrument for your specific application. With upper and lower set point adjustability, you can set the BGD to utilize the exact range that the engine / vehicle operates within and see exactly how rich or lean you are running in relation to your current set up and tune. Adjusting your BGD limits also adjusts the scaling of the 0-4v data logger output supplied from the gauge. The selected low set point of the BGD Range becomes the 0v value of the data logger output. The selected high set point of the BGD Range becomes the 4v value of the data logger output. Whenever you change these points, the instrument adjusts the data logger output so that the 0-4v signal is always linear between your chosen set points. "
Looks pretty good Theo. WOT input looks interesting, mine doesn't have that. Although the Innovate's have a built in data logger, whereas the Auto Meter seems to want one connected (which is probably the output you'd use for the F-con).
But at the end of the day it depends on whether the tuner wants to use it constantly, or whether you just use one of those ones you can stick in the tailpipe for the day.
My dyno has its own wideband that logs afr to the graph.
I have 2 standalone widebands that can be used for datalogging or roadtuning.
I recommend putting the wideband in for piece of mind, can then see if u have a lean out etc due to fuel surge or fuel pump failures etc
Howd it go today Theo :)
So all ur worry was a false alarm, the 02 sensor reading in the cypher software the Alex was reading from has no bearing on what the actual AFR's are. Tune was fine except for the 1 area which u heard a ping at low rpm high load which was very difficult to replicate on the dyno due to the auto but i found it and fixed it.
Ps, nice single pegger skid when u left :P
Very interesting today Jez- so we know stock ECU > Theos aftermarket computer> motor.
And I can only read what the stockie puts out.
Had a great run coming back down the old Pac- volvo convoy.
Nice :)
Yeah was very weird, especially how much difference there was in the ignition timing output from his aftermarket ecu to ur software
So second tune and no gains? C'mon Theo, slap a Hypergear in there... :P
All the stock ecu does now Alex is run the throttle and cams, nothing else has a bearing other than to keep the MIL away. I have no idea what signals the Fcon sends back to keep it happy but whatever it is, thank you mr HKS.
Jez also found some little parts of the pre-loaded tune that were no so good - and sorted them out.
I've got some logs from the power runs. Might load them if I can be stuffed
That's why I wouldn't use maps designed for other cars, you will always end up chasing gremlins in the tune imo.
Post them up Alex, I would be interested to learn what the Fcon is doing to the stock ecu and that may hold the key. If I end up going down the Link G4 route I may need the same signal bending output maps... The manual transmission will open up a world of possibilities. ;)
Honestly i wouldnt trust the log files as even the timing etc is way off
Exactly right.
As I said it goes Stock ECU > aftermarket>engine.
So Ign timing is not correct for the engine, but other things like Cams, AFM, and BFS are all able to be seen accurately.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
