I recently had all 4 CV boots replaced at Sydney Drive Shaft in Carlton NSW. CV joints were inspected and re-greased. They charged me $140 cash. I did the labour of removing them from the car and taking them to the workshop. They were done in just over an hour. For that kind of money I wouldn't bother changing the boots myself anymore. The only hassle I had was getting the CV shaft locknut off on the passenger side. I broke 2, half inch breaker bars [ irony ] and ended up borrowing a snap on high torque rattle .gun
i've just done the same and ordered the whole front set, problem is i cant get the drivers side front inner section out/off the transfer case...... i've undone the plate with the 5 bolts but it still wont release............. ive got the shaft out but i need the inner where the boot connects too.
passengers side was easy LOL :(
The drivers side just clips in, lever it out with a flat blade or similar, or tap it out with a Nylon hammer. Make sure you do the bolts up on the diff first, you don't want that coming apart.
Ah, I understand what you were talking about now; that's the bearing carrier.
I found using a tyre lever with a 90 degree tip is the perfect tool for removing the drivers side CV from the diff. I found it a little easier than the wide blade screw driver with adjustable spanner on the end of it.
Edited by bennyb110
thanks for all the help guys much appreciated!!!!!!!!!!!!!!!!!!!!!!
true that Alex but what do i change it too haha novice ?? LMAO
** it wont let me change the first post anyways so i cant change the title :P **
Edited by WAGON_BOY
  • 3 weeks later...
The title should be changed now, or else forever be known as a newbie!
Want me to change it to "Lambchop with an AXIS here?"
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
