its hard to see Dale cos its white and plain but once the bonnet is painted and glossy then it'll look really good.......
That is a sexy beast! Hmm bonnet upgrade one day maybe? Haha
Where did that bonnet come from? Modelled from a Dolphin or is it a Dolphin one?
yep its a freeway dolphin bonnet apparentely the first one thats popped up for sale in 4 years.
they dont make them anymore, so was lucky to pick it up second hand!!!
apparently when new they sold for $1600 but i'm hoping to make them for under $1200, going to speak to some mates but i'm thinking i need atleast 5-10 people who are keen to make it worth my while.
Any chance of a carbon one...?
couldnt be to hard LOL i'll sus it out aswell.
need to get corvettes secret in clear coating for that one LOL so it doesnt get UV damage!!!
  • 1 month later...
well after having a ball at Texi on Saturday my power steering is broken,
so its either I blew a pressure seal in the rack or the pump, its not leaking but it don't work.
at first I thought it was intermittent but now im pretty sure it doesn't work at all.
also a side note: maybe Alex would know, is the Series 1 and 2 power steering setups different seeing as the S2 came with a cooler? just wondering cos I would like to upgrade as I believe the S1 unit cant stand up to the abuse of full opposite lock drifting HAHA
I'm pretty sure the pump is the same, except a (piss small) cooler was added in one of the lines. It sits right at the front in front of the A/C condensor.
Your not running a P/S cooler? If not, get a small PWR cooler, and plumb it in the return line. I think several guys should be able to let you know their set ups. I think a seal in the pump unit is the first to go.
It's well known the pump will fail at the track without a cooler. Any small core will do, I am using a motorbike oil cooler but I have a spare small trans cooler here you could buy cheap if you want...
its called full lock drifting to much pressure/stress I would assume, I just wanted to know if the S2 pump or rack was different/better otherwise I will get mine rebuilt and modified so that this doesn't happen again if I decide to go drifting again.
like I said it wasn't leaking anywhere and I couldn't see it boiling in the reservoir and the cooler wasn't hot enough to burn my hand but that was after I felt it fail.
Did you use a spray can on the bonnet. Would look mad in 3m black or carbon vinyl wrap
yes I got the black off it and used a spray can so it wouldn't stand out as much to the police, but it'll be taken back off and finish being high filled and painted properly.
yeah it would look mad in black or carbon but I don't want it to stand out an pull unwanted attention :)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
