finally after getting the wrong coloured facia its all back together and I have a radio again!!!
I've put up a thread with the wiring colour codes in case anyone else needs to replace theirs, cant seem to link if for some reason though.....
Http://www.skylinesaustralia.com.forums/topic/437160-m35mradio-replacement-wiring-colour-codes/
Finally got my go-pro footage from the SAU track day back on the 29th of Oct 2013 @ SMSP south circuit.
here was my last run where I got a free run with no traffic and managed 3 awesome laps
2x 1:09's and a 1:10.
http://www.youtube.com/watch?v=dcvL4eyt1qY
best of the day was a 1:09.14 with consistent 1:09's all day long :)
starting to get p*ssed off with all the little niggly bits, so I'm going to try and sort them out before I loos my sh*t:
1) redo my headlights
2) need to get the bonnet struts as the fibreglass bonnet is to flimsy to support by the stock arm and so the AXIS bonnet add on is starting to fall off.
3) this radio change over has been a massive PITA, hate the aftermarket A/C buttons, and seems as though I've blown part of the BCM that controls interior lights, tail lights and parker lights so now I need to replace the BCM which seems more or a PITA than it should be.
4) need to tidy up my gauges as it looks like sh*t so going to have to pull my finger out and make a fibreglass one!!!
5) should probably replace my drive belts and fuel filter I'm guessing they are well over due!!!
6) need to get this window washer bottle cos its a PITA having a dirty window all the time that I cant clean whilst I'm out
once all this is done I might feel better cos atm I'm getting annoyed my cars turning to sh*t because of neglect!!!
ah well that's my rant for the week!!! :)
I still have no 6 in pieces. :domokun:
I'll get cracking.
You makin a washer bottle Dale?
I did a cardboard mock up about a billion years ago for Theo; will use the OEM filler neck, and the side also acts an air guide for his oil cooler.
I have all the sheet guillotined and bent, neck made, then we had another kid. :rolleyes: I need to machine some bosses for the pumps to push through then get off my arse & weld it.
I'm so busy at work now, I barely get time to do my paperwork in the extra hour I work on top of my 12hr shift. Weekends used to be fab time; not anymore.
It might hold a litre of water, with the neck volume added; a little more.
It's something I was interested to make for myself, sounds way too complicated to make multiples of though.
I would love to get a second oil cooler in there... Not like you need 40L of washer fluid anyway. :P
I have the advantage of being able to use my cardboard mock up for templates; I'll see what this one turns out like.
A litre odd would last long enough.
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
