  • 3 months later...
Haven't updated for a while not that I've really done much to it lately but did take it out to SMSP South Circuit again and managed to knock off another second off my lap time with a 1:08.26.
  • Like 2
cheers guys on the kind words :)
turbo and injectors and retune etc will be on the cars but it still seems to be going strong so not going to worry atm, busy on my RX808 wagon trying to get that finished :)
  • Like 1
  • 3 weeks later...
The cars been playing up since last Sunday, its like it wants randomly stall when cruising so what I'm thinking is maybe airflow meter or fuel filter, its due for its 105,000Km service so I think I'll give it the works and see how it goes after that.
But to make matters worse on Saturday a woman decided to side swipe my rear bar luckily no damage to the rear quarter, just another thing to piss me off!!! :(
If the airflow meter goes whilst driving it normally just goes straight into limp mode, but doesn't stall. That was my experience anyway.
Maybe a dodgy cam sensor? Or fuel pump? Would be easy to check if you can get a gauge.
They don't always throw codes either.
Same, my engine light is up most of the time with the Fcon, but the AFM really isn't needed once you MAP tune it either. Only the gearbox cares.
swapped the airflow meter with a spare Dale had bought from Scotty but the cars still running like crap and now the AFR's are way to lean.
cruising now sits at 12 rather than 14
and when I hit boost even light throttle 5PSI I'm probably going under 10. (usually max throttle I'll hit the low 10's)
so 1) is the airflow meter the same do is the voltage different ?
or 2) do I need to do a ECU reset and relearn ?
otherwise I'm going to put my old one back in and try and find the problem why the car's wanting to stall mid driving/cruising.
tomorrow I might see if I can get the data off my tablet from the last few drives I've done to find the error.
12 is richer than 14.
That is, 14 parts air, 1 part fuel.
So it's not in danger. However it does point to a potential issue. That is, intake or vacuum pipe/seal leak. So, it might want to stall from unmetered air on cruise, but leak air out under boost to make for a richer mixture as the afm is metering up stream.
Have a look at all pipes for disconnected hoses, or splits.
I thought the airflow meter was the problem cos the voltages were spiking so I replaced it but it didn't fix anything so yeah I guess there could be a Intermittent leak somewhere.
but all my vacuum lines are new so I'm thinking it might be a solenoid or something to do with the fuel line valves.......
Can you pressure test the intake to see if there are any leaks?
If there is no other reason for the change in AFR's I can send you another AFM to try... Unless someone up there can lend you one for a drive? Perhaps the Chinese one is slightly out? I would have thought it would be fine on cruise though...
Have you checked the O2 sensor is oscillating?
well I finished wiring the fuel pump and replaced the fuel filter.
replaced the oil and put back in my original airflow meter.
put a fresh tank of Shell Optimax in as well.
took the car for about a 45min drive and everything seems to be ok.
didn't find an air leak although its still quite possible I'll see how it drives over the next week or so.......
thanks for the offer Russell but I'll see how it goes for now haven't had any drama's yet and I've put my old afm back in.
the problem with Scotty's afm is I'll need to get a retune anyways :( or put a resistor on it to get the correct values like the stock one.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
