Hi all, will try to be as brief as possible.
Original problem:
-Fuel pump has been noisy in car since purchase, never gave trouble, just noticeable when priming or with the back seat out.
-In the process of re-doing my boot install for more "oomph" and boot room using a custom box, I need to seal over the pump access hatch with seam sealer.
-After this, changing the pump if it dies will require 2-3 hours work to access and re seal the hatch.
Solution:
-Bought a Walbro GSS-341, which will support any future needs power wise, and prevent the current pump dying down the track.
New problem:
-Went to fit the pump tonight, after removing the assembly the pump is at least 2 times bigger than the Walbro:
And has these markings:
Jecs A42-T02 12v
* 000 4222
Made in Japan
The * denoting the Nissan branding with the rectangle and circle.
From a quick search on google and here, I established that Jecs is like Bosch and makes OEM electronics, but the numbers don't match anything?
Is this pump the original, 160,000 km old item, a genuine replacement, or an upgrade?
Should I still replace it with the Walbro item?
Any help appreciated as I'm trying to get the car back together now. thumbsup.gif
https://www.sau.com.au/forums/topic/357892-quick-help-regarding-fuel-pump/
Looks like the standard fuel pump
The Tomei pump i put in was smaller then the standard pump, not by as much as the walbro but it was slightly smaller I remember that much
I assumed it was the original with the Nissan/Jecs brandings. Walbro's in now, much quieter and is doing the job thus far. I guess 17 years on things don't need to be as bulky anymore...
Edited by blk94r33
