Can you please try them for just a 19 row core posted to NZ (should be much the same price as Australia) ? I can pay you or them direct whatever suits.
  • Replies 334
Posted Images
Yeah. See what HEL say about the relocator, keen to hear.
Ok regarding the relocater. They have looked into getting a Mocal relocater as part of the kit a little while ago and never heard back from Mocal. So they will suss it out again and get back to me. Might be an option for a seperate group buy later if it will be a while off. Anyway i'll update on this as I find out more.
i'll grab a 19row kit phil.
doing the rb20/30 oil block is the way to go. for extra sensors just use a brass adaptor where the factory sensor is.
Ah yeah didn't really think about using an adaptor of some sorts. Good idea. (Not that I currently need the extra sensors, but others do). Added to the list man.
Thanks, missed the 80degrees comment watching Erics wakefield vids :) A good temp, those at 60 are just too low.
Looing forward to the DIY, and will hopefully fit the larger one as well.
Yeah I was quite happy at the 80 degrees. Exactly like you said, the ones around that 60 degre mark aren't really best suited for a street car. Also added to the list.
I'll see what I can do. Perhaps if the relocater kits get done seperately, we can do like a mix and match parts list aswell or something. I'll update on this aswell.
Bah! Put me down for one, I'll find the money somehow :P
19 row or a 25 row? :)
Very interested in an oil filter relocator aswell. :yes:
Yeah I think I might go one aswell. The stock position really is a pain in the ass, especially with a big Plazmaman plenum in the way.
Called into the local stockist (Alert Engineering) to price the 19 row Seatrab - around NZ$500 incl tax!!! They used to stock Mocal as well but he claims that they are now Chinese manufactured and not up to scratch!? BTW he also recommends 25row for 300kw up.
WhiteR33GTS-T said on the first page that he wanted everything but the core. Perhaps chat with him and organise something with you two getting one kit and splitting it between you two.
No idea about some Mocal parts being Chinese manufactured. Wouldn't suprise me though, what isn't made in China? There is a difference with a company getting something manufactured in China (like 99% of companies) and a Chinese company manufacturing parts.
EDIT: Just did a quick Google search and found that in house engineering, design and manufacturing gets done at Mocal's premises at Isleworth UK. So no idea about the China reference. Perhaps only some parts are made there.
So is the relocator just for convenience only? Also were you able to confirm how long the lines will be? I'm planning on mounting it on the passenger side at the front.
Also with the stock cooler plate that the water coolant runs through, i thought i read somewhere it was to also help bring the oil up to temperature when cold, or is this incorrect?
Yep relocater is just for convenience only.
Lines will be 2m. Passenger side duct is probably the only place that 2m might not be enough so if you want more lines let me know and I can see if your kit can get a bit more (possibly at a small cost, maybe $10-$20).
Yeah stock cooler plate also warms the oil up a bit when completely cold by using coolant. This is because coolant warms up at a quicker rate than the oil. I suppose this is one of those things every one can personally decide on if they want to get rid of it. Since I live in a hot climate for me it isn't a concern and hence I will be removing the whole thing.
cant believe im only seeing this now.... Im in :) that makes it 10 too I think :)
I guess ill go the 19row as 25 will be overkill for a fairly standard rb25 thats tracked every couple of months... right?
Yeah 19 row will be fine.
Most Japanese oil cooler cores are a lot smaller than these things and a lot of cars run them.
Addded to the list.
There really is no maximum numbers for the group buy since they are all getting sent out individually, but I think I might cap it at 15 at this stage so we can get the ball rolling.
If the total length is 2m i'll measure up over the weekend and get back to you. Do you think there would be a downside to running longer lines? Just wondering if there is a reason they only supply 2m.
Just means you will put a little bit more oil in.
I guess because most people install them on the drivers side or in the middle so 2m is usually enough and doesn't mean you have heaps of extra lines going every where.
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
