I only have 2 pics so far, both on Facebook so I'm sorry if they come up as red xs :P
Haven't plumbed it in yet as I ran out of patience for working in the rain :laugh:
  • Replies 334
Posted Images
Anyone got pics of this or so fitted to an R33 GTR?
Phil, I may have to talk to you about one of these soon.... or something like that.
  • 1 month later...
Hey Phil - have you fitted your yet? :P
If so did you document the install with pictures by any chance? I might try and fit mine in the next couple of weeks, would be great to find out about any of the pitfalls first :)
Anyone fit this onto a r32 Gtr?? My mechanic says it physically imposable to fit the thermostat sandwich plate... It is the correct thread but just does not fit. Any ideas? Oh and I think my kit was for a 33gtr I have a 32 with 33 engine. Iv been told they are the same... Any ideas? Cheers
could be there is not enough room for the fittings and also putting the filter back on. i put a justjap kit on a mates gtr and it was all good but that kit comes with a relocator for the filter.
don't the gtrs come with a thermostat in the factory oil cooler?
phil- are HEL still sending out the black hose & fittings?
Yeah they are. I gave them four guys addresses a little while back to send the fittings out to. Might shoot him an email to see if the other ones are ready.
Decided I would fit mine today, what a failure that was.
I was doing well until I realised that the Trust/Greddy relocate kit had different size hoses and fitting to our HEL kit. I currently have my car pulled apart with an oil cooler mounted but nothing attached to it. Should be a fun day tomorrow trying to see what my options are with new fittings or hose.
Guest
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
