  • Replies 42
Excellent, the other thread was getting out of line :D
I've got one simple question to get started......why does *anyone* want anything other than a 1 way diff? Under which circumstances do ppl want LSD affect under braking?
I saw one diagram in one issue of option jap mag suggest that 2 way help drift, since both wheels almost same speed enter apex, then driver will use conter steer to help enter conor..that's use my limited japanese. but maybe mean something else.
Also thanks to Steve post this link
How does the conventional diff work?
2 way, 1.5way or 1way?
I would think its 2 way as when compression locking two wheels lock.
Difference is I suppose the conventional diff isn't as tight.
Could a 1.5way diff actually help you corner? Possibly helping the front wheels turn in easier with less understeer? Giving a slight neutral feel if you like?!?
I am in the market for a diff soon. I was thinking about getting the stock diff shimmed up however it makes it basically a locker which is good for drift but no good for general street driving. Any one with experience how tight these shimmed diffs are would be great. I drive to Uni which = lots of U-turns or sharp turns to get in to car parks etc.
G'day Joel,
With my limited knowledge, I would say yes provided you are accelerating.
With my 2 way, there is a definate change between off and on throttle when going around a corner (as SydneyKid has discribed).
Off throttle going into the corner it will understeer a little (but is very easy to control, and on a track you probably wouldn't be driving like that anyway), and once you start to feed the power back on you can feel the back really pushing hard and will induce a bit of oversteer (again, really easy to control).
Sounds hard, but it's very predictable and consistant.
So I'd say that a 1.5 way would tend to understeer less than the 2 way, so for the street and track a 1.5 way would be the best. Although a 2 way would still be better than the stocker.
J
P.S. - the FM901's are getting pretty low on tread of late, and I've been giving them a bit of a hand :rofl: It's only now I know how predictiable these diff are :P
Nope, the sockie is a LSD (limited slip). So with the stockie it will let both wheels spin at different speeds, but it will just limit the amount of difference between them.
Think of it like this. Stock diff is limited slip, while a 1/1.5/2 way is no slip, it'll lock the wheels to the same speed (if your accelerating enough).
I think that reshimming the stock diff will just make it tighter, so the amount of slip that it lets happen is less ?? Can some confirm this ?
J
talking about "lockers" and "LSD's" : why do they seem to go hand in hand with mechanical diffs?
eg: "OS Giken Super Lock LSD" i gather this is a locker diff, so why do they put "LSD" in the title? Isnt it either a limited slip, or a locker?
Re-shimming the stock diff can be customised by the amount or thickness of shims, to give the effect you want. Ive heard of UAS reshimmed diffs over here being great for the street. In probably most conditions other than drifting, i found my stockie to be perfectly adequate for street, and if you dont want a pig of a diff, maybe just get it tightened up a little bit? i think this is possible...
my problem is that it my diff frequenly open wheels when puttin down the power.
Sometimes when i go WOT, i get major traction problems, the car pulls slightly to a certain side to say that they wheels are spining, yet its nothin like an oversteer where the rear end really steps out, it just slighty does. Now in this situation, are both the wheels spinnin, ie can the car pull to a certain side yet only 1 wheeling?
when i turn a corner slowly my inside wheel skips and it does not make any noises at all (like clunks), and when going around rounderbouts the car feel like it is pulling back and fowards (a surging feel).
do you think this is locker? I have been told that it may be just a tight cluch, but it skips even when I'm riding the clutch a little.
Any of you guys running coilovers?
Just thought I'd mention I have recently swapped to a set of coilovers which have been corner weighted and adjusted on the previous car (R32GTSt)
I used to have a problem of spinning one wheel contantly, but after installing the coilovers, the rear seems to be alot better, more even weight on each wheel i guess
It still has its moments though, so I am about to install one of those aluminim cradle bush kits to try and help it put more power through BOTH wheels!!
The diff will be the last thing I look at, as i dont want to transform it into a pig around town and through the hills, as most of my driving is done in either one of those
Mine does the same. Slowly its getting much worse.
Some times it is fine, I can launch with a 4200rpm and only have the wheels chirp all the way through first. Other times it will start then all of a sudden let go.
If give it a little stick on come on to boost in first while turning left, the inside left wheel will spin up and feel very gay as the car doesn't accelerate, doesn't go sideways the slightest & makes lots of noise.
The car's diff 2 years ago used to be really tight. Always sideways never open wheeled on hard cornering etc. But that was 60,000+ km's ago.. :)
Mine's got stock shocks and lowered springs, and the diff made a huge difference.
For me tho, its not about drifting around the local round about, I'm looking for traction out of corners, and the diff is great there. You can get on the gas far earlier than with my old, worn out stock diff
Mines a 1 way mechanical, and I'm very happy with it, cost me $500.
Still wondering about benefits of 2 way dif, I take the point that it may be better for drift but surely thats only a small difference (after all you are acellerating - or trying :) - when you are drifiting...) Any other benefits?
enrico, if the back end steps out, that usually means you are getting drive to BOTH wheels, but in a stock lsd like yours, you may be getting uneven power distribution, eg 70% power to your left wheel and 30%power to the right, and so it steps out just a little. So you may be openwheeling a bit. If both spin together as in a locker, you can feel the back end very consistent, and it will feel a little "floaty" as both wheels have broken traction.
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
