Hey. I just got my r33 gts-t back on the road. Redid the timing and she was running sweet. Had the timing fairly well advanced, and the car had lag issues before but the advanced timing via the cas fixed that. Went and did donuts and holding just below 7k and I have a feeling the radiator had not much liquid in it and it seemed to be overheating. After I finished spinning and pulled out from the burnout the car stalled. After I got the car started it seemed to idle alright, but there was a strange knocking noise and it seemed to be coming from the rear cylinder. So I got the car toed and haven't bothered to run it because I am afraid I might hurt the car.
It had been blowing white smoke too.
Does anyone know what could be causing it and or how to fix it?
Much thanks in advanced.
Matt.
https://www.sau.com.au/forums/topic/357935-r33-gts-t-knocking-noise/
In my experience with other older types of cars (not imports or nissans but hey an engines an engine right??) white smoke usually means water getting int o a cylinder from a f**ked gasket or cracked head hopefully just head gasket try letting it idle with radiator full and look for bubbles, if u get them then gasket. Theres another way where u use a compressor thru the spark plug holes and also watch radiator but Im not 100% on that one
Was there water in it in the end??
Edited by rickr333
It only seems to tap on idle, when the revs picked up it goes away I think. Could injectors cause this? higher fuel pressure at higher rpm masking the potential problem with the injectors?
@AaronNM35
Pretty sure it's stock so it would be tappets. thanks for the feedback :)
@rickr333
There was coolant in it, I had to dump it when we were looking at the engine. Thanks :)
Edited by mbwilding
Matt.
awesome combo :cool:
Matt.
I also am afraid.
.. why oh why did they get rid of the rep system - perfect opportunity for people to put it to use ..
+1 for you
Hey. I just got my r33 gts-t back on the road. I have a feeling the radiator had not much liquid in it and it seemed to be overheating.
but im sure you checked the oil level first....
Oh a loose conrod, that's not right...your engine timing must have been slightly out...can't think of any other cause. Tell your engine rebuilder to use a left handed torque wrench when he's torquing up the end caps...RB engines respond to them more positively than conventional torque wrenches...a lot of rebuilders don't know this.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
