theres always a chance on a low k car that it has been tampered with..but the condition of the car will give u a better indication then whatever is on the clock...that does seem like really low k's but maybe thats exactly what it is :thumbsup:
if in doubt and you have access to the car get a mechanic to do an inspection on it and get a professional opinion
hopefully it all comes back sweet tho, good luck
bit over 3000k's a year on average does seem a tad low, doesnt it? :/
is this a car your looking at buying or just one you saw?
Works out to be under 70km a week lol.
I would believe it if it was a R33 N1 GTR or something along those lines. Not a GTS.
Hmm interesting man, my brother bought his r34 sedan with 27xxxkm on the clock, in that time the only that has faild are the coilpacks. He's racked up about 40,000kms in 5 years. Just make sure there are no accidents/chassis damage, rust etc. And the engine has good compression, also check things like the condition of the belts, especially the timing belt
could be the real deal ya never know but like others have said have it looked at. if ther persion selling it gets defencive then you know its a no go but if the car looks great then you just have to flip a coin.
:cheers:
  • 4 weeks later...
the km's could be legit even if the condition of the car is pretty ordinary (not everyone treats their car great. i've seen near new cars with low kms but in terrible condition and vice versa). generally though it is a good indicator. the kms on an import are very rarely legit though.
the missus pulsar is a 2000 model and only has 70,000kms on it. would've been less but we went back to 1 car for a while. at one point when we had 2 cars though, her car would've been lucky to do 50kms a month as we always took my car. sometimes her car would go a week or 2 without even being started.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
