  • Replies 42
Wow. there is a bullshit amount of time been spent on the body of this thing..... and then just to drift it. haha. i drift myself but i couldnt bare to spend that much time on it. it is a top notch build non the less.
Grate job and plenty of different ideas comming together.
i have the drifting bug, it's not had any kind of motor or mechanical failure. once i finish this new exhaust setup off i can take it to places with noise restrictions such as lakeside. so im gonna enter sprint series next year. its down to just having to change a few suspension settings and this grips like all hell.
Got any pics of the haltech install and ls1 coils and what not?
no i don't sorry, but the haltech sits behind the head unit, and the coil-packs are behind the dash where the heater-box would bolt up. this car runs an electronic heater demister.
Edited by 32_Dave
this car is friken awesome, good on you man !
where did you get those clear headlights? im assuming the kakimoto regu 06&r is loud for street duties?
clear lenses my mate hughesy imports them, he goes by the name of freeworks > freeworks <
kakimoto regu 06r is so quiet its perfect for street, i put a dumper on for the track as the i get a good 1000-1500 rpm more spool from the turbo.. DAMNN that mid muffler, but its so nice to drive with.
im in the midst of toy-ing with a solenoid system
awesome build mate. good to see a young bloke not afraid to get in balls deep and give it a go. I know at 21 I wouldn't have gotten anywhere near that result mate. you should be proud.
  • 3 weeks later...
monster build dude!! man that thing gets sum lock!!
just a qs, just to confirm u using r33 crossmember? and a stok sump? and u were able to move engine back 30mm with no clearance issues?
sorry 4 the question s just doin a similar thing in my r30, tryn to find out sum info
cheers
  • 3 weeks later...
moar skiddss then 3rd lap and boom.
then fixed back up and out again for the last 1hr of the day, had to do a runner back home for spares. while i was doing said runner, photo shoot went down lol
more money more tires...
then 130km scando entryy happened and i failed... :( but that's motorsport
instead of running the wall i hit said wall so car came home ready for rev2. which is now in the works, giving myself 2-3months after mates onevia is completed.
pics of mates onevia in the works...
cheers
hey mate,
cheers man, lock setup is now sold, new setup going in soon :) moar!!! using r33 cross member racks moved forwards 20mm and is notched at the front too clear sump, also running stock sump.
CSTS are FOR SALE if anyone is keen, CHECK THREADS
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
