Hi there guys I have a 1993 Maroon/Red R32 GTST Coupe for sale.....The car was bought approx 6 years ago at 100,000km in standard form. Apart from a front mount and turbo back exhaust it is still in its original form. It does not even run a boost controller. This is probably why the only things that have ever been replaced have been a batery and a clutch. The car runs perfectly and everything works & it looks great with its GTR boby kit and 17" wheels.....Asking price is $5500 unregistered or $7000 with 6mths QLD rego....prices are firm....photos comming soon.
Pros:
Light weight 17" racing wheels
lowered suspension
Frount Mount IC
Turbo back 3" exhuast
GTR body kit
Sunroof
Cons:
Two small spots of rust (if bought registered will repair)
air con vent on passenger side broken......
https://www.sau.com.au/forums/topic/358026-r32-gtst-1993-model/
Would you be interested in swaps?
I have a 1994 180sx
SR20DET
Manual
TO4E TopMount Turbo
Custom Manifold
FMIC
3"
Fuel Reg
eBoost
I dont come on here much so if your keen msg me on 0466406071
    • My first thought is to use something like this https://www.bunnings.com.au/goof-off-177ml-adhesive-remover_p1580913
    • Here it is nice and clean and for shits n giggles he's the clearly structural piece of trim it was holding down. 馃槵
    • A lot of the trim pieces on the E39 are super brittle and just dissolve when you try to get them off. It looks like a previous owner has used what can only be described as an industrial construction foam adhesive to glue down a tiny piece of trim.  Unfortunately this part of the tailgate is starting to rust because of how much shit is in here. This is stopping the water draining and there's a big build-up of dirt that is just staying wet. How can I remove this? Would a flap disc get rid of this?  I think this car spent a lot of time inland. There's so much light coloured, fine dirt and dust everywhere.  Sorry for the pic. I've cleaned this all up now so I'll get another pic of it clean today.
    • Surely, just about any shop that has done a Skyline (or Supra, or RX-7, or EVO, or WRX) will have done E85. But perhaps you need to specify what type of car, what type of engine, what ECU, you propose to be using.
    • Try an oil additive. There's a couple of options for "easier shifting". These are essentially a similar idea to what Redline put into their Shockproof gear oils. I had a 2nd hand R33 (in fact, as of right now, it is still in the car) that simply would not engage any gear with the engine running, with normal gear oil in it. We dropped that and replaced it with Shockproof lightweight, and suddenly the gear lever did what it was supposed to. At a cost, of course, of the then ongoing damage to internals done by running Shockproof. But the synchros were already totally uninterested in life, so there was no loss.
