Hi fellows,
Just getting a Nistune for my R34GTT this week - got usual stage 1 mods - intake, turbo-back exhaust, FMIC, boost controller at 12psi, plugs..
Been to Uni Group, Unique Autosports, Croydon, Powertune so far.. Powertune seems to have the better price of the lot, but they seem to mostly do EVOs and Silvias..
They quoted me $610 for install Nistune board onto my ECU and have it tuned ( I buy the board separately ). Is that a good price?
Anyone can recommend a reasonably priced and GOOD tuner in Sydney who will not do a quick n dirty job? Am just after a nice sharp STREET tune.. :thumbsup:
https://www.sau.com.au/forums/topic/358039-nistune-tuner-in-sydney/
  • Replies 54
Yavuz at unigroup engineering, does alot of Rb engines and knows damn well what he's on about. He may charge a little bit more then some of your other quotes but when it comes to tuning ya want the best!
Edited by GTR_JOEY
The type 4 board on it's own is 460 so you are up around the 1100 dollar mark
http://www.nistune.com/equipment-products-type4.php
Unigroup do them for that.
I have nothing against powertune but i honestly see them more as an excellent developer of bespoke parts, like their manifolds, gear box adapters, fuel pump cradles, injector rail kits etc, first and a tuner second.
I see unigroup as a tuner (and cam designer/supplier) before anything else.
Thanks for the replies - btw Dave, you do not need the licence for the Type 4 or any Nistune board (leave that to the tuner) - the board itself is $260 + GST. I spoke to Yavuz, he is a very nice bloke who definitely knows what he's on about, unfortunately his price is pretty steep.. If they were all the same price then he would be my pick, unfortunately I do not own a money tree yet..
You're going about this the wrong way.
The lowest price isn't the way to find a good tuner. Good tuners can charge more as their time is valuable and they get the results owners want.
Asking a tuner to lower their price is actually quite rude IMO, their prices reflect their work and customers get what they pay for
Also think of this, how much time and effort would YOU give a job if you know you're not making much money from it compared to a job where the owner didn't come in and screw the price down?
Yavuz can increase his prices and I'll still go there.
i will happily back the above statement as well.
been there many times for different tunes, each time I am so impressed with his quality of work and he is always happy to explain everything to the "technically challenged" such as myself. He is a master at what he does.
Just ask yourself this. Yeah Yavuz might seem expensive to you, but if it's 'expensive' and people are still lining up outside the door. What does that tell you?
It's all about the tune dude! Why you wouldn't be spending a sh*t load on that I don't know...
i've had my car tuned at envy recently (put a nistune in my silvia that previously had power FC) and I was happy with the work. they supplied the ecu, board and tuned it. I would also be happy going to UAS. i've had my GTR tuned there before (long time ago, before nistune, it was a power FC tune) and I was also happy with their work.
i haven't been to the others so can't comment on them. bear in mind any workshop has it's happy and un-happy customers. I would speak to a few tuners and just pick whichever one you are happy dealing with.
hey steve your signature says u own a Supra TT - just curious, r they that MUCH better than a R34GTT ( I know the 2JZ is a lot stronger than a RB26, let alone a 25) - how do they go on the street if you have driven both with similar mods???
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
