What are peoples opinions on single turbos on an rb26 - I have up to 2k to spend on the turbo alone
I was looking at a T04E with a 1.06a/r - where would something like this be on full boost by?
Other options were GT30R 1.06 and 0.86 or GT35R (yep still under 2k) - how would these compare eg spooling/full boost/power production
Or else 2nd hand turbos, anything
If anyone has any answers to any of the questions, or their own thoughts I'm more than keen to hear
The car will be used everyday, track bla bla but I'm more interested in a nice powerful 'responsive' turbo with plenty of potential later on down the track
Cheers fellas
https://www.sau.com.au/forums/topic/35806-rb26-which-single-turbo-up-to-2k/
depends if u r after 360degree thrust bearing (rebuildable) or ballbearing (spools beta)
the 35R should spool damn quick wit the .82 rear, i would go the 1.06 in the 35r
depending on the front of the T04E would depend when it hits full
all those turbos should b on full no later than 3500-3800 wit a custom manifold
the T04E is the definite cheapest turbo of the lot round $1100 brand new
the others are $1700+
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
