Cheers bud. Hope this thread enlightens others. Glad your happy with the 71. I've decided on the 76 with 52t and will order tomorrow or we'd. Will post up the info and results for future reference when I get it
Thanks
  • Replies 119
Posted Images
  • 2 months later...
will scan dyno sheet soon.
ended up making 270 @ 16psi
feels great, full boost by about 3800 with small can actuator. will be great with poncams and big can
freaking love it!!!!
big thanks to Willall and AM Performance
If its a "real" GT3076R 52T it may convince a few people thats its a better thing than the 56T version .
To be fair making 270kw (GT3071/GT2835s can make that power) with full boost at 3800rpm is no way near being a compelling arguement in the direction of it being a better thing than the 56T.... its spooling about the same as a 56T but has less flow potential.
*lithium double checks his turbo id tag*
*finds he actually has a 52T.....*
for me i probably would have been happy with either of the turbos. but the 52t is what i went with to be a little different, and its great. hey, the 56t may be exactly the same. As you can see 270 @ 16psi, hits nearly 18 in mid range. im thinking big can actuator and a set of poncams should be additional fun. tag on the turbo that i wrote down was 700382-10 . once the big can arrives well play around with the boost controller a bit more. any questions or comments welcome. All i know is its fun!!
i have also included a picture of the AM Performance dump pipe before it was polished. can get you a better pic if needed
Id be very happy with that. You can pull a bit more fuel out of it and can certainly wind in a bit more boost.
The big can actuator might also bring things on a reasonable amount earlier also, which would make it even better.
Congrats.
  • 7 months later...
never really updated this. well here it was as of a few weeks ago. currently sourcing bigger gate springs and going e85 in the next week or so
Been playing around with the car of late.
previously had
269@ 18psi falling off to 16 (263 run printed)
Nismo 555 injectors
greddy profec b
Garrett 3076 52t .82 internally gated 1 bar actuator
Tomei Poncams
98 octane
usual front mount and 3" exhaust
z32 afm
changes
3076 52t with .63 rear
Tial 44mm external gate
made 236 @ 15psi falling to 14 (no boost control other than the spring in the gate)
*there was no tune done with the new rear set up due to going e85 in the next month or so
verdict
boost comes on a LOT earlier, but no issues with traction. I do miss the power in the top end though, really punches coming out of corners.
plans
E85 + 18psi + 740cc injectors should see me back around the 270ish mark and be back to being awesome with great response. anything more and it does start to become unusable. when the car was making 270 it was great on track, but really lacked low end pull
also worth noting a few friends have the 56t version with identical set ups, the 52t has no where near the high pitched spool noise as the 56t, it does try though
This was the kind of result I was hoping to see on an RB25DET with the 52 compressor trim GT3037/GT3076R - and with the 0.63 AR turbine housing .
Corky Bell said years ago that you can't have good response down low and that meaty top end with the one turbine housing . You have to make your own decision on which compromise you want , mine will be the one that suits what I do with my car most of the time which is not using the meaty top end so much .
Possibly the saddest thing is that Garrett unlike HKS never made a 0.73 AR GT30 turbine housing and the one HKS do make has a GT28 flange and no integral wastegate .
Right at the bleeding edge the 56 trim GT37 compressor in the 0.60 AR T04E housing can churn enough air for about 540 Hp but I doubt you'd get near that without the 1.06 AR turbine housing and a pretty big exhaust . Besides I reckon it would be laggy on an RB25DET .
Personally I don't think much of the 71.1mm or GT35 compressor wheel teamed up with the GT30 turbine . This is not to say they are an unworkable combination but I don't think there is anything brilliant they can do given a choice of turbos . Someone here said differently but I have never seen
a GT3071R with a port shrouded compressor housing , they normally have a plain snout 0.50 AR T04E housing ant I've never seen a port shrouded 0.50 E one .
The GT37 52T compressor is the one HKS specified when they though things could get laggy . It was an option for SRs and in twin form on RB26s .
I don't see the point of having compressor capacity you don't intend to use so for all round IMO the 52T GT37 compressor looks pretty good on an RB25 . At least with these the worst you may have to do is change turbine housings if its too laggy or the top end not to your liking .
Turbos aside you can do things like headwork and bump the CR a little to give it a bit more low down engine only torque . If I was rebuilding one I'd use the Neo head and pistons to suit because I think the more compact chambers was probably aimed at better lean running detonation resistance . Bit more timing bit better burning bit closer to the boost threshold etc etc .
Its all fine till the wheels spin then the AWDs eat you ...
A .
Well hopefully the e 85 tune will be Monday. Planning on fitting my new gate with 18.8 psi spring and getting a power run so I can go back to back with e85 againt pump. Imo the .63 rear ex gated is perfect for the rb25. I'm hoping to nudge 300rwkw with e85 and 19psi
With external wastegates there is always the opportunity to adapt GT28 flanged GT30 turbine housings , the hassle is moving the turbo out further and altering plumbing to suit .
Also search the Mafias threads/posts because he claimed to have I think ~ 320 Kw with a 56T GT3037/GT3076R in a 0.63 IW GT30 housing .
He used WMI which can be arguably simpler than high Ethanol content fuels .
A .
Given with E85 you should be able to make 300kw even with a GT3071 I see no reason to go for a 76 unless you want >300kw. I see no issue with screwing a bit more boost in, I mean why would you stop with the 3076 anyway, you'd just keep screwing more boost in to make more power.
Matt from nistune made 300kw with poncams and a neo rb25 with a 0.82 internal gate 3071 on BP98! Probably the best result I've ever seen, was done at morpowa here in Adelaide by Pete who is also from Nistune, he reckons the dyno is far from happy.
Matt does have very high quality parts on his car, proper jap intercooler and everything else is not cheap.
If you go on the nistune forums you can see the dyno sheet and discussion surrounding it.
Edited by Rolls
