what gear was 18psi at 3000 on ya gt? My GTX is prob 3800 @ 21psi second gear internal gated on 98 :whistling:
yeah im thinkg bout the .82 external wastegate 56t on bp98 i used to have a 3071 that made 280rwkw on 18psi but wasnt a very big pull but now i have a different rb25 which is alot healthier
  • Replies 119
Posted Images
mate if you want an easy 300 go the kando t67
it is arguably similar in response to a 56T 3076 but is $800 delivered and actually gets about 330kw on 20psi
800 will buy you a 3076 housing... its good value and theres a massive thread on them now. please read it.
I think the T67 is a fantastic turbo but needs an external wastegate and really should have an aftermarket exhaust manifold compared to the 3076 which does not need either so puts it really in the next category up.
never really updated this. well here it was as of a few weeks ago. currently sourcing bigger gate springs and going e85 in the next week or so
Interesting on your graph - it almost looks like the 56T is actually surging around the 3000rpm mark.
My GT3040 (the 600hp one) did a similar thing, wasn't quite as severe but it also started to ramp, drop away a little, and then re-ramp again.
It was *barely* audible unless in specific conditions, but it was hurting the performance none the less.
Did you notice any surge around that point with the 56T? It's certainly not known for it!
Be interesting to compare our setups once mine is on E85 next week as our setups are similar :thumbsup: when are you seeing full boost and what size are your injectors mate?
Ive got 850cc injectors a tomei pump and a GTX3071R internal gated
Full boost in 4th is about 3200. Didnt change at all when I went e85. And I'm using nismo 740cc and Bosch 044 pump.
Nismoid; Mines the 52t. I don't notice any surging
The comparo graph though (from page 3) the blue line vs the red line.
Ah mis-read, so it was a 52T just a housing change.
The blue graph has very "suspect" dips that usually come with surge as mine was exactly the same, interesting either way :)
If ya didnt notice then might have just been tune or something.
yep.
also it seems its down about 20rwkw at the 3080rpm marker over both other set ups.
Martin did say it kept wheel spinning around the 3000rpm mark, would that do it also.?
Well wheelspin would cause those dips
But it shouldn't be turning tyres if strapped right or the ramp rate gets changed to suit
This tune was done on federal RSRs. The last one on potenza re001s that were a lot wider.
The only thing that's changed between then is the fuel and the rear tyres. And last time it had no dips. Might just go back with the potenzas and see how it goes
  • 3 weeks later...
in the interest on science, and because i love changing turbos, i recently pulled off the 52t .63 rear and put on a 56t .63 rear just to see what the difference was for the turbo coming on, with unsurprising results. The difference seems to be negligible with boost coming on 150rpm earlier back to back. same dyno etc.
next step is to go to a .82 rear and see if that will solve the surge issue. as the .63 really didnt like it when i went e85 and whacked some boost into it
will be doing this next week
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
