what gear was 18psi at 3000 on ya gt? My GTX is prob 3800 @ 21psi second gear internal gated on 98 :whistling:
yeah im thinkg bout the .82 external wastegate 56t on bp98 i used to have a 3071 that made 280rwkw on 18psi but wasnt a very big pull but now i have a different rb25 which is alot healthier
  • Replies 119
Posted Images
mate if you want an easy 300 go the kando t67
it is arguably similar in response to a 56T 3076 but is $800 delivered and actually gets about 330kw on 20psi
800 will buy you a 3076 housing... its good value and theres a massive thread on them now. please read it.
I think the T67 is a fantastic turbo but needs an external wastegate and really should have an aftermarket exhaust manifold compared to the 3076 which does not need either so puts it really in the next category up.
never really updated this. well here it was as of a few weeks ago. currently sourcing bigger gate springs and going e85 in the next week or so
Interesting on your graph - it almost looks like the 56T is actually surging around the 3000rpm mark.
My GT3040 (the 600hp one) did a similar thing, wasn't quite as severe but it also started to ramp, drop away a little, and then re-ramp again.
It was *barely* audible unless in specific conditions, but it was hurting the performance none the less.
Did you notice any surge around that point with the 56T? It's certainly not known for it!
Be interesting to compare our setups once mine is on E85 next week as our setups are similar :thumbsup: when are you seeing full boost and what size are your injectors mate?
Ive got 850cc injectors a tomei pump and a GTX3071R internal gated
Full boost in 4th is about 3200. Didnt change at all when I went e85. And I'm using nismo 740cc and Bosch 044 pump.
Nismoid; Mines the 52t. I don't notice any surging
The comparo graph though (from page 3) the blue line vs the red line.
Ah mis-read, so it was a 52T just a housing change.
The blue graph has very "suspect" dips that usually come with surge as mine was exactly the same, interesting either way :)
If ya didnt notice then might have just been tune or something.
yep.
also it seems its down about 20rwkw at the 3080rpm marker over both other set ups.
Martin did say it kept wheel spinning around the 3000rpm mark, would that do it also.?
Well wheelspin would cause those dips
But it shouldn't be turning tyres if strapped right or the ramp rate gets changed to suit
This tune was done on federal RSRs. The last one on potenza re001s that were a lot wider.
The only thing that's changed between then is the fuel and the rear tyres. And last time it had no dips. Might just go back with the potenzas and see how it goes
  • 3 weeks later...
in the interest on science, and because i love changing turbos, i recently pulled off the 52t .63 rear and put on a 56t .63 rear just to see what the difference was for the turbo coming on, with unsurprising results. The difference seems to be negligible with boost coming on 150rpm earlier back to back. same dyno etc.
next step is to go to a .82 rear and see if that will solve the surge issue. as the .63 really didnt like it when i went e85 and whacked some boost into it
will be doing this next week
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
