what gear was 18psi at 3000 on ya gt? My GTX is prob 3800 @ 21psi second gear internal gated on 98 :whistling:
yeah im thinkg bout the .82 external wastegate 56t on bp98 i used to have a 3071 that made 280rwkw on 18psi but wasnt a very big pull but now i have a different rb25 which is alot healthier
  • Replies 119
Posted Images
mate if you want an easy 300 go the kando t67
it is arguably similar in response to a 56T 3076 but is $800 delivered and actually gets about 330kw on 20psi
800 will buy you a 3076 housing... its good value and theres a massive thread on them now. please read it.
I think the T67 is a fantastic turbo but needs an external wastegate and really should have an aftermarket exhaust manifold compared to the 3076 which does not need either so puts it really in the next category up.
never really updated this. well here it was as of a few weeks ago. currently sourcing bigger gate springs and going e85 in the next week or so
Interesting on your graph - it almost looks like the 56T is actually surging around the 3000rpm mark.
My GT3040 (the 600hp one) did a similar thing, wasn't quite as severe but it also started to ramp, drop away a little, and then re-ramp again.
It was *barely* audible unless in specific conditions, but it was hurting the performance none the less.
Did you notice any surge around that point with the 56T? It's certainly not known for it!
Be interesting to compare our setups once mine is on E85 next week as our setups are similar :thumbsup: when are you seeing full boost and what size are your injectors mate?
Ive got 850cc injectors a tomei pump and a GTX3071R internal gated
Full boost in 4th is about 3200. Didnt change at all when I went e85. And I'm using nismo 740cc and Bosch 044 pump.
Nismoid; Mines the 52t. I don't notice any surging
The comparo graph though (from page 3) the blue line vs the red line.
Ah mis-read, so it was a 52T just a housing change.
The blue graph has very "suspect" dips that usually come with surge as mine was exactly the same, interesting either way :)
If ya didnt notice then might have just been tune or something.
yep.
also it seems its down about 20rwkw at the 3080rpm marker over both other set ups.
Martin did say it kept wheel spinning around the 3000rpm mark, would that do it also.?
Well wheelspin would cause those dips
But it shouldn't be turning tyres if strapped right or the ramp rate gets changed to suit
This tune was done on federal RSRs. The last one on potenza re001s that were a lot wider.
The only thing that's changed between then is the fuel and the rear tyres. And last time it had no dips. Might just go back with the potenzas and see how it goes
  • 3 weeks later...
in the interest on science, and because i love changing turbos, i recently pulled off the 52t .63 rear and put on a 56t .63 rear just to see what the difference was for the turbo coming on, with unsurprising results. The difference seems to be negligible with boost coming on 150rpm earlier back to back. same dyno etc.
next step is to go to a .82 rear and see if that will solve the surge issue. as the .63 really didnt like it when i went e85 and whacked some boost into it
will be doing this next week
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
