Garrett have sold out of GTX stock worldwide, there is certainly a lot of interest. There must be plenty of builds in the pipework.
It looks like you have your answer, GT3071 will be the obvious choice. :thumbsup:
  • Replies 119
Posted Images
I have/had the GT3076 0.82 IW, I found it a little bit laggy for my liking, but I still enjoyed it, I was pulling ~265rwkw at 15psi
You also have to remember, everyone's case/experience with these turbos is going to be different because of different set ups. So what may work well for someone else doesn't mean you are going to get the same results.
I would maybe suggest the GTX3071 or strongly suggest the GT3076. Maybe speak to Morrie at Horsepower in A Box, he has played around a little bit with the new GTX series - GTX3076 only I think, can't remember.
Sounds like you have 3 choices in 0.82 IW:
- 3071
- 3076 52 Trim (Disco's choice)
- 3076 56 Trim
The earlier on the list the more responsive and the less top end. The later the less responsive and the more top end. Although we are not talking huge differences between all of them, maybe 3-400rpm in response and say 20-30rwkw in top end.
Joeyjoejoeshabadoo (sp) seems to be the ideal Case for 3071 (admitantly 2835 .67 or something). Making 260ish at 1 bar. Full boost about 3300. Sounds perect in theory
it is ;)
dan (halle) has just changed from a 2835 to a 3037, so he should have his old kit for sale...
- 3071
- 3076 56 Trim
FWIW I've tried both the 3071 and 3076 52 trim with twin scroll .78 rear housing on my SR20.
With a 3.5 inch dump/exhaust (up from 3 inch) I managed to get the 3076 52 trim making more mid range than the 3071. To make it clear, the 3076 52 trim was more livelier than the 3071 at any rpm.
The 3076 52 trim is a great "no compromise" turbo compared to the 3071 for 290+ rwks'. At this level of power, traction is an issue and is probably no use making more for a rwd street car. BUT if you want more.....just add E85!!
The only downside (if you call it a downside) is that the 3076 makes alot more spool noise than the 3071 due to the surge slots in the 3076 compressor housing.
Edited by juggernaut1
i wish you had done that back to back without changing the exhaust man :/
Don't think things would have improved, and possibly worsened/caused damage as the 3071 was already surging when coming onto boost wih the 3 inch exhaust.
A better flowing exhaust would have possibly made it surge more when coming onto boost. The surging tells me I couldn't put any more boost into it when coming onto boost so I doubt it could make any more power in the mid range.
The surge slotted 3076 52 trim allowed me to at least match the 3071 to build boost and make significantly more mid range in the process - probably because A - it was not surging and B - it was possibly a cooler/denser intake charge with the slightly larger compressor and C - with the larger dump there was a bigger pressure differential across the turbine when coming onto boost which pulled the 3076 onto boost earlier than expected.
I.e on the dyno the 3076 52 trim was making positive pressure by around 2300rpm, 1 bar at around 3350rpm and 1.5 bar (22 psi) by 3750 rpm on a sr20.
I had a similar experience, Mine was a little laggy but made 300 odd RWKW at 18psi so it was pretty good. But in changing to a RB26 with twin HKS2510s I realised how much better 300 rwkw could feel!
Did you have the 56 Trim 3076?
What ever trim is the same as what HKS uses for the RB25 3037....so from my fuzzy memory I think that is the 56T. I have pics of the ID tag somewhere. If i remember i will go look it up!
cheers guys. all info is massively helpful. something like the 3037 was what i was after but the $$ isnt there for a genuine kit. im now leaning towards to 3076 with 52t, but any more helpful info is appreciated
not quite, i rang MTQ and they have in stock, a touch over 2k though
that sounds pretty much perfect, with a reasonable top end to boot.. this seems the best compramise between spool and top end.
while your on the dump pipe topic. ive read a split dump set up on the garret IW set ups arent ideal and a 'bellmouth' set up works better? the rest of my exhaust is a 4" magic cat and 4" cat back so that back pressure should be ok
thanks again
Yeh, I would never buy from here for that reason. For much the same price I got the GTX 3071, Tial 0.82 stainless Vband housing and a 45mm turbosmart wastegate delivered, I just have to wait for stock... :dry:
So in the end much of a muchness and either should do the job? Been doing some research this arvo. Plenty of info on the 76 with 56 trim on RB not alot with the 52. so if it's comparable to the 3037 (even with the rear housing difference) then there's also alot
thanks again
I've had the CES split dump pipe on the stock s15 turbo. Never had it on a dyno but it was a fantastic upgrade from a seat of the pants feel.
However, depending on the quality of the split dump and how soon after the slit dump merges back into the main exhaust can give varying results (good and bad). My current setup has the external gates merging back in just before the cat i.e. merge it back in as late as possible. On IW setups there have been mixed results as I previously mentioned. I think the concensus is to go a quality bell mouth setup.
I'm no expert, but this ^ is kinda what i've gleaned from this thread.
I have a 3071 56T .82 and love it. Not having had a 3076 or any other Garrett turbo i suppose it's easy to say that, however i don't think the differences in trim and comp wheel size are really worth fussing over *too* much.
(This all assumes that the rest of your setup is sorted)
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
