Safc II Or Aftermarket ECU..?
hey,
Car: r33 GTS-T (5spd)
Mods:
HKS Super Drager exhuast
HKS SSQ Bov
Aftermarket Turbo (unknowen what type possible highflow, bigger than stock but not that much)
AirFilter + CAI
R34 GT-T Cooler
Bleed Value
Extra Heavy Duty Clutch ($900 or so)
Running @ .6bar
ok now that is out of the way, my question is, is it worth buying a ecu or should i just buy safc II for the time. I would like to make 300 to 350rwhp out of my car (my end goal) so i was thinking that ecu would be the better idea in the long run.
saying that i am unsure of which ecu to pick from, I live in perth and i know of a 2 good tuning houses which can tune Wolf3d and have had good reason (e.g. SST r32 gtr running 10second 1/4). But some people having being tellin me that Apexi PowerFc is the way 2 go but i dont know anyone who can tune it in perth :confused:
so i am very :confused: @ the moment
p.s after i pick ecu/safcII i will be buying a FMIC
Thanks Mike
edit: I have done a search and come up with general answer but would like some base on my car and it mods thanks
the reason people say power fc is that its plug an dplay and if you have epa problems you can jsut plug tour stock ecu in along with the other stock stuff.
power fc would be a good choice s-afc youwould spend your money twice. but would do the job .
the r34 cooler is bigger and more efficentthan the stock r33 one.
i thought the Wolf3D uses the factory sensors and is plug and play for the 33Ts.. Mikey, in the long run, the ECU would give u more control over the SAFCII in so many ways.. boost, timing, fuel, rotational idle, antilag etc as opposed to the SAFC which is basically a fuel computer..
the 34GTT core is thicker than the 33GTST stock cooler :P
i think you should get the FMIC in first, then have the ECU put in and tuned
Get a license first... and then a brain.
can i ask why u have given this respond?
i seem 2 be getting all the person attacks and i cant understand why i have stop asking stupid question, and general want some info about ecu over safc
Because you have asked this same question over and over and over again in the WA whoretown thread and I am sick and tired of giving you replies when you dont listen to the advice given.
rob, in whoretown it is not here or there, i just ask random , pointless question as the thread said it is whoring (i have stop that now). I now wanted info on ecu types and also befits on safc and ecu. im sorry but if u r sick and tired of me then just dont read my topics and reply in such a way that it is just a personal attack on me
So because its been said in whoretown it isnt valid? You need to get used to the fact that this is a forum and I can voice my own opinion.
ok after doing a search, on wolf3d i have come to the conuslion that it is the ecu for me, i just have a few question about stuff.
what is the knock snesor..? i read that u have 2 buy an add 4 wolf homuch does it cost?
and would it be wise 2 upgrade injectors and fuel pump after installing wolf?
You'll need to upgrade the fuel pump before the wolf goes on, as for injectors probably not, just get them cleaned and flow tested before pushing the engine, if 1 injector is down on flow it can blow the engine.
 Share
