Sucks to see the car go Adam! You did a good job on it! Have to say how fun is Sydney Motorsport park!!! We went there for the top gear festival and was so fun haha
The colour almost looks the same as our corolla! Looks awesome in the sun!
  • 8 months later...
Hey, so it’s been a while huh? I’ve been a ghost for quite some time, on here and various forums. I lost my interest in cars for a while and funnily enough I started playing car roulette again.
The Skyline was sold to Jeff as the mortgage is more important than a car I’ll barely drive. Shortly after I sold the R33, I scored a job as an order entry/business to business support clerk for one of the worlds largest navigation companies. With that in mind I set out to get a fun simple daily, so I went back to my roots. I bought a Mazda Roadster.
It was a very neat example, and a fun car to drive. A perfect base for a simple, enjoyable car. But things went another way when Benny decided it was time to move on himself. He kept nagging me about the Stagea and how I should be reunited with it. For a while I just brushed it off but when I started loosing interest in the Roadster for an IS200 … I thought about the Stagea long and hard.
The conclusion I came to was I put too much time, effort and money into it and I really couldn’t be bothered (nor do I have the luxury) to do anything that extensive to a car again in the near future. It was at a point where I could tie up loose ends and enjoy it for what it was. So I gave in, the Roadster went on the market and sold shortly after which made my reunion with the Stagea set in stone.
Although it’s back in my grasp, it’s not how I remember it. The first owner took a few things off it like the brakes, and suspension components along with the R33 LSD. Over time all these things will be rectified when I can find the time and/or money to do so. There are a few other little details that I’ll be fixing along the way too.
One day, I might even be out on the track again getting this thing sideways, at least I hope so.
  • 1 month later...
Spotted this @ Mona Vale around 5:30 tonight, walked into the sushi train and was spotted by a bloke I used to work with at Supercheap and is the current owner of this??
He has been through more cars than I eat meat pies xD. Hope he looks after it, great looking car in person.
Edited by M35woah
  • 6 years later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
