Adam here is my thread that you will find VERY helpful its got all the info i gathered and pictures from a heap of different sites that i visited....
http://www.skylinesaustralia.com/forums/topic/331327-my-manual-conversion-findings/page__hl__manual+conversion
Parts list:
R32GTR 4WD Gearbox - Preferably push type as clutches are cheaper
Flywheel- 9 Bolt Turbo type and bolts
Clutch, pressure plate and bolts- and a thrust bearing to suit
Bellhousing bolts- M10 x 1.5 60mm and some washers to suit
Clutch pedal - R34gtst
Clutch bracket - R34gtst
Brake Pedal cover from manual car - r33
Handbrake - R32
Clutch master cylinder - R34
Clutch line - 650mm Long stainless steel clear coated braid with banjo bolt on one end and jam nut on other
Centre console - Auto plastic welded/modified for the stick and handbrake from sau
spigot bush - get one with clutch kit
Clutch slave cylinder - Get one with your gear box
Handbrake mount - Cut of trans tunnel of wrecked 33
Skyline primary shift boot
Shifter
gear knob
R33 foot rest
Transmax Z for Transfer case and attesa reservoir
box oil
got these in during the week ... should have quite a bit more coming this week (hopefully)
and fitted one of these suckers
build the pressure
Oh yeah, took it skids on Friday too, starting to use full lock now, which is perfect timing as I have some inners/outers coming in.
Edited by RoadsterGarage
Boing!
The BC Racing BR coilovers for the Nissan Stagea are odd, the rears are height adjustable until your chassis is laying frame, but the front is a completely different story. So for a temporary measure, I had the springs compressed to “guesstimate” what height spring I needed to order.
The new spring size ordered was 150mm long which is just about perfect. Check out the gap between the coils, whoever says compressed springs don’t effect ride comfort must be on crack! Not only were they a harsh ride, they would also bind on hard bumps.
The new springs were installed without much hassle, and are much better than the compressed pieces of shit. Now I can go as low as I want!
box of goodies – Part I
Y’all know about that big order that keeps on accumulating, well most of it has actually arrived! The first batch consisted of Greddy catch cans, Nismo gear knobs, HID kits and some Bride material.
The only thing I ended up fitting was the Greddy catch can. After about 20 minutes of figuring out where to put it that is.
No idea when I’ll fit up the other gear from this order, but hang tight!
box of goodies – Part II
Here’s the second batch of goodies in my Garage, these goods were organised by Rod at Tetsuya Garage over the past few months. This batch includes a NA grille, Works Bell boss kit, Kouki tail lights, KTS inners and outers, books and all sorts of other shit.
Oh, there’s also a manual centre console chilling in the above photo too.
So, the only thing left to do was to get it all fitted. I started with the easiest thing first, the eyelids. I realised half way through the order that I realised that these weren’t the eyelids I was after. But mocking them up on the car, I don’t mind them at all.
Next up was the grille, those factory clips are a pain in the ass to remove, but we got them off in the end. The grille transforms the front of the car completely, and I dig it.
To finish the night off, Aytac and I tackled the rear tail lights. These were an absolute bitch to replace. We needed to rip out the whole boot trim (or as much of it as we could) and then fight the sealant in the centre lights. I ended up snapping the Zenki centre lights trying to get them out. We managed to finish up at 2:30am. But it was all worth it.
The car is starting to come together now, I’d like a front lip and a few other things to tie the cosmetics together, but we’ll see what happens huh?
Hurro Kitteh fitted!
Seeing that the Works Bell boss kit arrived yesterday, I decided to get it fitted. I actually intended to fit it last night but upon removing the OEM steering wheel, I realised that Nissan used security keys. So I had to get a socket to suit before I could do anything.
Other then that, it was all smooth sailing, and I had the boss kit installed within the hour. It’s amazing how heavy the OEM wheel is, I would say that it would be at least 5KG heavier then the new setup.
Not only does it look better, I’ve got more leg room too! Steering feels lighter too suprisingly. Now I want to get all the Kazama and KTS parts in, adjust the cars height and get an alingment.
Ok, now we are up to date!
NA grill makes the front of the S1 look so much better, one of the easiest and best visual mods i have done on mine i think.
Love how quickly you are getting stuff done, it makes me feel bad about my own progress though haha
Sunday morning 7am, I was still awake from my fourteen hour sleep the day before, bored and eager to do something. After smashing up COD for multiple hours with Aytac I thought it would be a good idea to do something productive.
I headed out to the garage and had a look at these clear indicators from Japan. The indicators I ordered were for a Nissan Cefiro, which happen to share similar indicators to the R34 and Pulsar, with the only difference being the plug shape/size. So, I got out my files and started grinding into the back of the indicator, until the Stagea’s plug fit. This probably took me an hour to do. After that I managed to get some shut eye.
Also, my Bride style seats arrived and just purchased a Greddy E-manage Ultimate with a Kouki WGNC34 tune for a bargin price!
So next up, I want to fit all my adjustable arms, get an alingment and put in the brides before next skidpan. I might paint the eyelids too.
Then sort out things like intercooler, dump pipe and manual parts while I wait for the Emanage to arrive before the conversion starts.
Still going hard I see Adam.......great work...love the dedication towards the cause!!!....I don't think I have seen you put a foot wrong in this build yet!
Keep it up
hahaha, cheers guys!
Just edited a photo I took last week cause I was bored.
Hopefully I'll fit the adjustable arms I have lying around tomorrow and get an alingment on Saturday ... will be the first one for this car lawl. Oh, I want to sort out the height a little still to ... just a tad more low :)
Edited by Run-It-Hard
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
