  • Replies 155
  • 1 month later...
lol damn, was some misinformation d1nz!!!
got the stuff from the gtr now but clutchslave won't fit rb20 gearbox, clutchmaster is too big and won't fit in the stock-clutch holes, gotta drill some new holes or just a stock cefiro clutchmaster...
clutchpedals fits surprised straight on, but the pedal is too near to the brakepedal what makes it stupid, gotta bend the pedal a bit out of the way from the brake.
on my A31 the driver sits on right side, don't know maybe there's a difference that the stuff i got didn't fit...
Hey M8, Just cut the Auto brake pedal on the left side to make it the right width and put a pk screw through the pedal rubber to hold it on looks dk and works perfectly. Jamind, A31 SE4
i already cut the brakepedal and its rubberthing down^^
i also bend the clutchpedal straight that its not that bad close to the brakepedal and looks natural :whistling:
all this is just for a 32 gtr clutchpedal! other models are different...
btw r32 gtr clutchpedal got a booster too, it won't fit right in it needs modification for that, i just used a r32 gtst clutchmaster cylinder it fit right in(a31 clutchmaster is the same)
if somebody want pictures tell me...
so my non turbo cefiro rear brakes matched up to be same as the,
Bendix Part Number:
DB1144 - REAR
does this mean;
-rb20e
-rb20de
-rb20det
-rb25de
modeled cefiro's all come with rear turbo brakes?
just to add my front non turbo brakes were slightly bigger then sr20de front caliper, but smaller then the sr20det caliper
Edited by Dan_J
You'd prob be right about Thailand, Asia (ex. Japan), South American, etc Cefiro's (all LHD).
What about the LATE late model ones. LHD Laurels and Cefiro's were made and sold up to 1997, and sometime between 94-97 they came factory with 5 stud.
My understanding was all Cefiro's, from 20E to 25DE came with the same brakes front and back, which are very similar to SR20 brakes but not interchangeable.
I've offered my whole brake setup for free to couple of Sil owners and they rejected, claiming it's different to SR brakes...
Beats me. Skyline brake upgrade FTW.
Edited by Nic_A31
reason i ask is that i swaped what i now believe are s2/3 round plug coil packs for the spare set of r32 rb20 i had laying around into my engine.
now i started to get the missfire above 4-6k where as my original ones did not missfire even tho the r32 ones looked in better condition and even had 'coils' on the end of them unlike my cefiro ones which where burnt out
so ceffy coils stamped 185 / 135 / 1xx
and r32 coil 3xx
  • 3 weeks later...
  • 1 month later...
was it like that when u got it? could be the central locking unit or the brake light relay somehow.... something in the boot, have a look around
Hey Dan.
yeah the central locking has never worked.. the drivers side rear door will do the auto lock thing at above 20kph and will lock when i lock the drivers door. but wont unlock and no other door will lock or unlock.
brake light relay you say?? how so?
also ive noticed lately that while im driving around there is a clickin coming from the passenger side door, not sure if front or rear.
but basically its the same clickin that happens if i press the door lock button on the drivers door handle.
well awhile ago i swapped my brake light relay unit with another similar looking unit i had laying around( which i found out to be a r33 relay of some kind ) which made my central locking not work at all.
so just swap the long black brake light relay thats mounted on your boot wall with your c33 mate
The tailshaft just depends on if its ABS or non ABS.
R33 diffs can fit. The 5 bolt axles are a direct fit into the existing hubs.
Most Cefiro's have a 4.36:1 ratio, so S13, diffs are the go.
If you want to use another ratio, you'll need to get the speedo drive from the same vehicle and chuck that into your box, so your speedo stays in sync.
hey dan.
another question about the central lockin in the laurel..
i was at a local wrecker the other day and found a ceffy. its mostly gone but the lock acuators were still there so i grabbed em.
went to put them in but they are way different.
so i decided to see if i could figure out why mine dont work.
and it seems that its the acuators them selves that are f**ked as wen i plugged in the ceffy one it would work.
so i took them out and the arm that goes on the gear to the motor was really loose. pulled them apart and couldnt figure out how they are ment to work. ended up figuring out that they use a spring.
anyways..
question. is it possible to fix them. if not do you know of any replacement for them?
cant say i know too much about the central locking actuators them self so i camt help there, although like any car u can get generic/brand name central locking kits with the actuators.
the only stuffing around is finding the right type that will mount with some mods and making sure it'll wire into the factory wiring and relay well.
not much help but i guess have a chat with a car security/alarm installer
yeah. hopefully i wont have to go down that path. bein doin a bit of research and it looks as tho r32/33 skyline actuators are the same/similar.
and from what i found when i was pullin mine out. they are universal fit.
ie the 1 actuator will fit every door as you can just flip it/turn it to suit what ever orientation is required.
fingers crossed. ill post up in the parts section if i get them to work
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
