Hi all
A lot of you will know that all too familiar sound when the bearings in your turbo decide to slowly seize up. I knew my car wasn't running well on the "Children of the Dark" crusie but I didn't think it was this terminal.
Anyway, after a couple of days reading forums I think I've got the following options:-
1) Rebuild the original turbo (going to Per4manz or otherwise)
2) Get a replacement 2nd hand stock item
3) Second hand used item other than stock (HKS 2530/2535 or similar)
4) New turbo
5) Send to CGC for highflow of original.
Basically, I don't want to have to bother with new tubular manifolds or the like and would rather something that bolts into the stock location. Oil and water lines can be made if necessary as can dump/front pipes.
What would you all recommend. Budget is $2,500 absolute tops. (I've just spent $4K on rebuild so I'm strapped for cash). Car is R33 S2 with FMIC, clutch, 910 fuel pump, S-AFCII, EBC and forged pistons.
If anyone is suggesting new turbo, any suggestions where in Perth?
Cheers!
Dave
https://www.sau.com.au/forums/topic/35814-its-turbo-time/
  • Replies 52
Rumour has it that turbo tech have ball bearing balancer? maybe you wont have to send to cgc to get it high flowed as ballbearing still? to Hi flow yours in perth, with plain bearing, will cost you about 1300 bux, leaves some money to spend elsewhere in car or in life. This turbo on your set up should see around 330 rwhp on about 1 bar.
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-714848
speak to grant at per4manz about hiflowing your original turbo with sierra internals!!! YEEEEAAAAHH!! sierra internals are abou the biggest that can fit in our turbo... quite nice reallly ... thats what i got on my puppy and works a treat... ask skyzer and mrsnrub (ben) how my turbo goes, grant did a great job for the money i spent and am well happy.
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-714974
KamikazeR33: PM Replied. Sorry!
Everyone else, a summary
Rebuild/Replace stock turbo in WA with thrust bearing turbo: $1300 +
Order new HKS turbo from Japan (greenline/takas/nengun etc) :$2000+
Order new standard turbo from Nissan: $1800 ish
Highflow stock unit by GCG: $1950 + shipping each way (450HP Stage 1)
What do you all think?
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-715858
per4manz turbos do a t3/t4 brand new for $2000-$2200, bolt on to standard dump and manafold, no mods to oil lines. at one bar looking at around 350rwhp with better midrange response than stock. iv just fitted mine and should be getting tune next week.
when comparing to a hks say 2530 its around same price as a second hand, flows more and is a bolt on fit.
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-716315
am running 314 with bugger all timing added there is heaps to be added as i have forgies in there now... thats next time at SST plus Cam Gear is out.... way out... i would say around 340 rwhp to 350 rwhp should be achieved.....at about 17 psi.... all in all quite happy with it....
if money conscious then go the sierra hi flow......yummmm bit bigger than t3 t4 and sounds the goods too :-) can't remember how much grant charges but find out and speak to him before ya do anything 1st...
I;m trying to buy a crap car around 1g to drive to mt lawley zest.... if i can find one then i will start putting money aside for a nice plenum and so on and so forth... plenum i think would go nicely with my turbo ;-)
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-716403
Ok now you can go and do something a bit more respectable down at the drags to further sell the story of the new found power :) 314rwhp should get you a nice mid 12, especially if the turbo is gutsy in the mid range.
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-716465
GT25R has T25 flange right? Also, who in Perth sell them? Or is that another net purchase?
Thanks for all the replies. Rob77, I'll take you up on the offer one day too, would love a ride in your car. At the moment I'm leaning toward the HKS2530 option but obviously open to the Garrett equivalent. I'm trying to get a straight answer from someone as to how "bolt on" an HKS turbo really is. (ie does the dump pipe match up, pipe to AFM, pipe to cooler, oil + water lines)
I'm a little hesitant to go back to thrust bearing cause i know I like the instant response of my current ball bearing unit. It's probably being fussy but that's just me :D
Dan, no worries on threadjack and thanks for info on Per4manz turbo option. Maybe i'll need a wrap in your car too :)
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-716470
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
