wrxhoon was keeping a register of engine numbers for a while. but you can't cross check to a vin in fast.
in addition to the heater hose size above
32 gtr has 2 plug mounts at the rear of the fuel rail
33 gtr has a plug mount at the front and a plug mount at the rear
34 gtr has a different cas.
not a lot of practical differences though
Water outlet towards the back under the plenum is larger on R33
Fuel rail has 2 mounting tabs toward the rear on R32 ....R33 has one to the front
On the R32 harmonic balancer the two large seperators are the same thickness....the R33 one is a little thinner (front)
If it has the turbos the O2 sensors are smaller on the R32
All of these thing can be interchanged so its not diffinite either way...
Maybe post up the first 3 digits of the engine number maybe someone might be able to help you from that
  • 3 weeks later...
