Hey guys,
Looking for an r33 speedo drive urgently. Last thing I need to get the RB25 conversion going. Let me know ASAP.
Willing to pay for postage as well.
Located in Melbourne
Cheers, Jason
https://www.sau.com.au/forums/topic/358160-wtb-r33-speedo-drive-required/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
